ObjectsBatch Class Reference
Class containing batched data of a detected objects from the object detection module. More...
Attributes
int id
 Id of the batch. More...
OBJECT_CLASS label
 Objects class/category to identify the object type. More...
OBJECT_SUBCLASS sublabel
 Objects sub-class/sub-category to identify the object type. More...
OBJECT_TRACKING_STATE tracking_state
 Objects tracking state. More...
std::vector< sl::float3 > positions
 Vector of positions for each object. More...
std::vector< std::array< float, 6 > > position_covariances
 Vector of positions' covariances for each object. More...
std::vector< sl::float3 > velocities
 Vector of 3D velocities for each object. More...
std::vector< sl::Timestamp > timestamps
 Vector of timestamps for each object. More...
std::vector< std::vector< sl::float3 > > bounding_boxes
 Vector of 3D bounding boxes for each object. More...
std::vector< std::vector< sl::uint2 > > bounding_boxes_2d
 Vector of 2D bounding boxes for each object. More...
std::vector< float > confidences
 Vector of confidences for each object. More...
std::vector< OBJECT_ACTION_STATE > action_states
 Vector of action states for each object. More...
std::vector< std::vector< sl::uint2 > > head_bounding_boxes_2d
 Vector of 2D bounding box of the head for each object (person). More...
std::vector< std::vector< sl::float3 > > head_bounding_boxes
 Vector of 3D bounding box of the head for each object (person). More...
std::vector< sl::float3 > head_positions
 Vector of 3D centroid of the head for each object (person). More...
This class can be used to store trajectories.
Variables
◆ id
int id
Id of the batch.
◆ label
OBJECT_CLASS label
◆ sublabel
◆ tracking_state
◆ positions
std::vector<sl::float3> positions
◆ position_covariances
std::vector<std::array<float, 6 > > position_covariances
◆ velocities
std::vector<sl::float3> velocities
◆ timestamps
std::vector<sl::Timestamp> timestamps
◆ bounding_boxes
std::vector<std::vector<sl::float3> > bounding_boxes
Note
They are defined in sl::InitParameters.coordinate_units and expressed in sl::RuntimeParameters.measure3D_reference_frame.
1 ------ 2
0 ------ 3 |
| Object | 6
4 ------ 7
◆ bounding_boxes_2d
std::vector<std::vector<sl::uint2> > bounding_boxes_2d
Note
Expressed in pixels on the original image resolution, [0, 0] is the top left corner.
A ------ B
| Object |
D ------ C
◆ confidences
std::vector<float> confidences
◆ action_states
std::vector<OBJECT_ACTION_STATE> action_states
◆ head_bounding_boxes_2d
std::vector<std::vector<sl::uint2> > head_bounding_boxes_2d
Note
Warning
Not available with sl::OBJECT_DETECTION_MODEL::MULTI_CLASS_BOX_XXX.
std::vector<std::vector<sl::float3> > head_bounding_boxes
Note
Warning
◆ head_positions
std::vector<sl::float3> head_positions
Note
Warning
