Class containing data of a detected object such as its bounding_box, label, id and its 3D position. More...
Functions | |
| ObjectData () | |
| Default constructor. More... | |
| ~ObjectData () | |
| Default destructor. More... | |
Attributes | |
| int | id |
| Object identification number. More... | |
| String | unique_object_id |
| Unique id to help identify and track AI detections. More... | |
| int | raw_label = 0 |
| Object raw label. More... | |
| OBJECT_CLASS | label |
| Object class/category to identify the object type. More... | |
| OBJECT_SUBCLASS | sublabel |
| Object sub-class/sub-category to identify the object type. More... | |
| OBJECT_TRACKING_STATE | tracking_state |
| Object tracking state. More... | |
| OBJECT_ACTION_STATE | action_state |
| Object action state. More... | |
| sl::float3 | position |
| Object 3D centroid. More... | |
| sl::float3 | velocity |
| Object 3D velocity. More... | |
| float | position_covariance [6] |
| Covariance matrix of the 3D position. More... | |
| std::vector< sl::uint2 > | bounding_box_2d |
| 2D bounding box of the object represented as four 2D points starting at the top left corner and rotation clockwise. More... | |
| sl::Mat | mask |
| Mask defining which pixels which belong to the object (in bounding_box_2d and set to 255) and those of the background (set to 0). More... | |
| float | confidence |
| Detection confidence value of the object. More... | |
| std::vector< sl::float3 > | bounding_box |
| 3D bounding box of the object represented as eight 3D points. More... | |
| sl::float3 | dimensions |
| 3D object dimensions: width, height, length. More... | |
| std::vector< sl::uint2 > | head_bounding_box_2d |
| 2D bounding box of the head of the object (a person) represented as four 2D points starting at the top left corner and rotation clockwise. More... | |
| std::vector< sl::float3 > | head_bounding_box |
| 3D bounding box of the head of the object (a person) represented as eight 3D points. More... | |
| sl::float3 | head_position |
| 3D centroid of the head of the object (a person). More... | |
| ObjectData | ( | ) |
| ~ObjectData | ( | ) |
Default destructor.
| int id |
It is used as a reference when tracking the object through the frames.
| String unique_object_id |
It can be either generated externally, or by using generate_unique_id() or left empty.
| int raw_label = 0 |
Object raw label.
It is forwarded from sl::CustomBoxObjectData when using sl::OBJECT_DETECTION_MODEL::CUSTOM_BOX_OBJECTS.
| OBJECT_CLASS label |
| OBJECT_SUBCLASS sublabel |
| OBJECT_TRACKING_STATE tracking_state |
| OBJECT_ACTION_STATE action_state |
| sl::float3 position |
Object 3D centroid.
| sl::float3 velocity |
Object 3D velocity.
sl::InitParameters.coordinate_units / s and expressed in sl::RuntimeParameters.measure3D_reference_frame. | float position_covariance[6] |
position_covariance[i] | std::vector<sl::uint2> bounding_box_2d |
[0, 0] is the top left corner. | sl::Mat mask |
mask.isInit() == false). | float confidence |
From 0 to 100, a low value means the object might not be localized perfectly or the label (sl::OBJECT_CLASS) is uncertain.
| std::vector<sl::float3> bounding_box |
| sl::float3 dimensions |
| std::vector<sl::uint2> head_bounding_box_2d |
[0, 0] is the top left corner. | std::vector<sl::float3> head_bounding_box |
| sl::float3 head_position |
