Bodies Class Reference
Class containing the results of the body tracking module. More...
bool getBodyDataFromId (sl::BodyData &bodyData, int bodyDataId)
 Method that looks for a given body id in the current bodies list. More...
Attributes
sl::Timestamp timestamp
 Timestamp corresponding to the frame acquisition. More...
std::vector< sl::BodyData > body_list
 Vector of detected bodies/persons. More...
bool is_new = false
 Whether body_list has already been retrieved or not. More...
bool is_tracked = false
 Whether both the body tracking and the world orientation has been setup. More...
sl::INFERENCE_PRECISION inference_precision_mode
 Status of the actual inference precision mode used to detect the bodies/persons. More...
BODY_FORMAT body_format
 Body format used in sl::BodyTrackingParameters.body_format parameter. More...
The detected bodies/persons are listed in body_list.
◆ getBodyDataFromId()
bool getBodyDataFromId ( sl::BodyData &  bodyData,
int  bodyDataId
Parameters
bodyData[out]: sl::BodyData to fill if the search succeeded.
bodyDataId[in]: Id of the sl::BodyData to search.
Returns
True if found, otherwise false.
Variables
◆ timestamp
This value is especially useful for the async mode to synchronize the data.
◆ body_list
std::vector<sl::BodyData> body_list
◆ is_new
bool is_new = false
◆ is_tracked
◆ inference_precision_mode
Note
It depends on the GPU hardware support, the sl::BodyTrackingParameters.allow_reduced_precision_inference input parameter and the model support.
◆ body_format
