NVIDIA® Jetson AGX Orin™ Developer Kit enables the development of full-featured AI applications for products based on Jetson Orin modules. It includes a high-performance, power-efficient Jetson AGX Orin module, and can emulate the other Jetson Orin modules that will be launched on the market before the end of the year. It is now available for purchase on .
Upon completing the oem-config procedure, the developer kit reboots, and you should see the Ubuntu desktop like this on the display.
Open a terminal window by hitting Ctrl + Alt + t
Check your L4T version
cat /etc/nv_tegra_release
You may get something like this, # R34 (release), REVISION: 1.0, GCID: 30102743, BOARD: t186ref, EABI: aarch64, DATE: Wed Apr 6 19:11:41 UTC 2022, and this shows that you have L4T for JetPack 5.0 Developer Preview.
sudo apt update sudo apt dist-upgrade sudo reboot sudo apt install nvidia-jetpack
Download the latest ZED SDK for AGX Orin (e.g. ZED SDK for L4T 34.1 Beta) from the Stereolabs website.
cd ~/Downloads # replace with the correct folder if required chmod +x ZED_SDK* ./ZED_SDK_Tegra_L4T<l4t_version>_v<ZED_SDK_version>.run
Please replace <l4t_version> and <ZED_SDK_version> with the correct values, e.g. ZED_SDK_Tegra_L4T34.1_v3.7.4.run.
Please do not hesitate to share your projects with us by publishing amazing pictures and videos, and tagging @stereolabs3d on Twitter, Instagram, Facebook, TikTok, YouTube, and LinkedIn.
