Tutorials
Jan 14, 2019.
Getting Started
Requirements
  • Oculus Rift or HTC Vive VR headset
  • ZED Mini
  • Leap Motion with VR kit
  • Unity 2017.1 or greater
Hardware Setup
If you haven’t already, make sure you’ve installed the ZED SDK and Leap Motion Orion.
Setting Up Unity
  • Download the ZED Unity plugin and import it into Unity using Assets -> Import Package -> Custom Package
  • Do the same with the Leap Motion Unity Core Assets
  • Enable VR by going to Edit -> Project Settings -> Player, then in the Player menu, opening XR Settings and checking Enable XR
  • Open the ZED Planetarium example scene via the Project window via ZED -> Examples -> Planetarium -> Scene
  • In the Project window, navigate to LeapMotion -> Core -> Prefabs and drag the Leap Rig prefab into the scene.
Combining the Rigs
  • Expand ZED_Rig_Stereo, right click on the Camera_eyes object and click Create Empty. Name it “Leap Offset”
  • Expand Leap Rig and click on Main Camera
  • In the Inspector, disable the Camera component – we’ll be using the ZED’s camera for the final image instead.
  • In the Leap XR Service Provider component, set Device Offset Mode to “Transform”. This causes the rig to follow a particular object instead of the VR camera.
  • Drag and drop the new Leap Offset object from the Hierarchy into the Device Origin field
  • Without closing the scene, take off the headset, select Leap Offset and adjust its transforms to line it up properly. The Y position is most important, but make sure to move your hand around to make sure all axes are properly aligned. If using a Vive, you may also need to adjust the X rotation slightly.
  • When you can see in the Game window that Leap Offset is in a good place, click the gear icon in the top right of Leap Offset‘s Transform component, and click Copy Component
  • Stop the scene
  • Click on that same gear, followed by Paste Component Values
  • Save the scene
Adding Physics
  • In the Project window, navigate to LeapMotion -> Core -> Prefabs -> HandModelsPhysical
  • Drag and drop RigidRoundHand_L and RigidRoundHand_R to the Hand Models object in the Leap Rig to make them children of it
  • Select the Hand Models object.
  • In the Inspector under Hand Model Manager, expand Model Pool and Capsule Hands
  • In the Left/Right Model fields, replace the Capsule hands with the RigidRoundHands you just added.
  • Delete the Capsule Hands that are children of Hand Models
  • Expand the Planetarium object, and the Earth object below that
  • Select all the planets, the Sun, and the Moon (a child of Earth) at once. In the Inspector, add a Rigidbody component
  • Uncheck Use Gravity and check Is Kinematic on these new Rigidbody components
  • With the objects still selected, also add a Sphere Collider component
  • Select the objects individually and adjust the Radius value of the Sphere Collider until you see its bounds fit the planet in the Scene window
Result
Yujin Ariza
Yujin Ariza
@YujinAriza
·Follow
building a food chain #mixedreality #vr #leapmotion #zedcamera #oculusrift
Watch on Twitter
237
Reply
Read 6 replies
Yujin Ariza
Yujin Ariza
@YujinAriza
·Follow
Watch on Twitter
237
Reply
Read 6 replies
Kadek
Kadek
@KadekASatriadi
·Follow
Need more tea! #madewithunity @Stereolabs3D @LeapMotion
Watch on Twitter
24
Reply
Read more on Twitter
