  • Tutorials
    Apr 22, 2019.
    How to Set Up a Multi-Depth Camera Network
    Lower TCO (total cost of ownership): Since ZED cameras don’t need their images processed locally, they can run on low-cost intermediary devices such as the NVIDIA Jetson Nano, cutting down on hardware setup requirements.
    General Workflow
    Software Setup
    • ZED SDK 2.8 or greater installed on all Senders and Receivers
    • Local network connecting all Senders and Receivers
    Sender
    1. Open the ZED camera with open()
    2. Set the streaming parameters
    3. Call enableStreaming() with the streaming parameters
    4. Grab the camera frames with grab()
    5. Disable the streaming before exiting with disableStreaming()
    // Open the camera
    zed.open();
    stream_params.bitrate = 8000;
    while (!exit_app) {
         zed.grab();
    // Disable streaming
    zed.disableStreaming();
    Refer to the following table to choose the ideal bitrate for your situation:
    Encoder
    Resolution
    FPS
    bitrate (kbps)
    AVCHD (H.264)
    HD2K
    HD1080
    HD720
    15
    30
    60
    8500
    12500
    7000
    HEVC (H.265)
    HD2K
    HD1080
    HD720
    15
    30
    60
    7000
    11000
    6000
    Receiver
    1. Set the input from the desired IP address and port by using setFromStream()
    2. Open the camera with open()
    3. Grab images directly from the stream with grab()
    // Set the input from stream
    // Open the camera
    while (!exit_app) {
       if (zed.grab() == SUCCESS) {
          // Any processing
    // Close the camera
    zed.close();
    Use getStreamingDeviceList() to list the available streaming devices. This function returns the IP address and port of all valid Senders present on the local network.
