H.264/H.265 hardware encoding is supported on Jetson Nano, TX2 or Xavier. From remote streaming to video recording, learn more about the encoding capabilities of your Jetson.
Board | Family | H.264 | H.264 | H.265 | H.265 |
Jetson Nano | Maxwell | YES | YES | YES | YES |
| 1x | 4x | 1x | 4x |
Jetson TX2 |
BOARD | FAMILY | H.264 | H.264 | H.265 | H.265 |
| 2x | 8x | 2x | 8x |
Jetson TX2 | Pascal |
Pascal
YES |
YES |
YES |
YES |
| 3x | 14x | 3x | 8x |
Jetson Xavier NX | Volta | YES | YES | YES | YES |
| 2x | 14x | 2x | 14x |
Jetson Xavier | Volta | YES | YES | YES | YES |
| 8x | 30x | 8x | 32x |
YES
YES |
YES |
YES |
| 4x | 14x | 4x | 14x |
| 2x | 16x | 4x | 32x |
| 8x | 32x | 12x | 52x |
