Stereolabs introduces the new , and Edge Computing solution based on the powerful NVIDIA Jetson modules. Two options are available today: NVIDIA TX2 NX or NVIDIA Xavier NX for more performance.
Want to know more? Email us at: support@stereolabs.com
