Lower TCO (total cost of ownership): Since ZED cameras don’t need their images processed locally, they can run on low-cost intermediary devices such as the NVIDIA Jetson Nano, cutting down on hardware setup requirements.
Sender
open()enableStreaming() with the streaming parametersgrab()disableStreaming()// Open the camera
zed.open();
stream_params.bitrate = 8000;
while (!exit_app) {
zed.grab();
// Disable streaming
zed.disableStreaming(); Refer to the following table to choose the ideal bitrate for your situation:
Encoder | Resolution | FPS | bitrate (kbps) |
AVCHD (H.264) | HD2K | 15 | 8500 |
HEVC (H.265) | HD2K | 15 | 7000 |
Receiver
setFromStream()open()grab()// Set the input from stream
// Open the camera
while (!exit_app) {
if (zed.grab() == SUCCESS) {
// Any processing
// Close the camera
zed.close(); Use getStreamingDeviceList() to list the available streaming devices. This function returns the IP address and port of all valid Senders present on the local network.
