NewsTutorials
Jun 28, 2015.
Using the ZED Camera With OpenCV
Important: This article is outdated (ZED SDK 1.2). Please see the new OpenCV guide here.
Redirect me to the updated tutorial
Introduction
depth grab
Code
Explanation
** Using ZED with OpenCV
#include <iostream>
// OpenCV
// ZED
#include <zed/Camera.hpp>
// Input from keyboard
char keyboard = ' ';
  // Quit if an error occurred
  if (err != sl::zed::SUCCESS)
    delete zed;
    return 1;
  // Create OpenCV windows
  // Settings for windows
  // Loop until 'q' is pressed
  while (keyboard != 'q')
      // Retrieve left color image
      // Retrieve depth map
    keyboard = cv::waitKey(30);
  delete zed;
#include <iostream>
// OpenCV
// ZED
Do not forget to add the links to OpenCV (headers and libs) and ZED SDK (headers and libs).
1. Initialize the ZED camera
  delete zed;
  return 1;
2. Create OpenCV windows
Now, assuming the initialization was correct, we can create our OpenCV matrix and OpenCV windows with the correct resolutions and types.
3. Capture and display color image and depth
Let’s write our main loop. The simplest way is to create a ‘while’ loop and handle all the events with OpenCV.
And that’s all we need! You can now build and run the application. You should see on your screen the two following windows: “Depth” and “Image”.
depth grab
