Lower TCO (total cost of ownership): Since ZED cameras don’t need their images processed locally, they can run on low-cost intermediary devices such as the NVIDIA Jetson Nano, cutting down on hardware setup requirements.
Sender
open()
enableStreaming()
with the streaming parametersgrab()
disableStreaming()
// Open the camera zed.open(); // Set the streaming parameters sl::StreamingParameters stream_params; stream_params.codec = sl::STREAMING_CODEC_AVCHD; // can be AVCHD or HEVC stream_params.bitrate = 8000; stream_params.port = 30000; // port used for sending the stream // Enable streaming with the streaming parameters err = zed.enableStreaming(stream_params); while (!exit_app) { zed.grab(); } // Disable streaming zed.disableStreaming();
Refer to the following table to choose the ideal bitrate for your situation:
Encoder | Resolution | FPS | bitrate (kbps) |
AVCHD (H.264) | HD2K | 15 | 8500 |
HEVC (H.265) | HD2K | 15 | 7000 |
Receiver
setFromStream()
open()
grab()
// Set the input from stream InitParameters initParameters; initParameters.input.setFromStream("127.0.0.1", 30000); // Specify the IP and port of the sender // Open the camera ERROR_CODE zed_error = zed.open(initParameters); while (!exit_app) { if (zed.grab() == SUCCESS) { // Any processing } } // Close the camera zed.close();
Use getStreamingDeviceList()
to list the available streaming devices. This function returns the IP address and port of all valid Senders present on the local network.
