  • News
    Sep 16, 2022.
    Getting Started with ROS 2 on Jetson AGX Orin™
    The performance of the new Jetson AGX Orin™ unlocks capabilities such as processing 3D data coming from multiple ZED 2i Depth Cameras, making it the ideal combination for autonomous robotics and edge analytics solutions. It is now available for purchase at the Stereolabs store.
    NVIDIA Jetson AGX Orin
    Install the ZED SDK on Jetson AGX Orin
    cd Downloads
    chmod +x ZED_SDK_Tegra_L4T<os_ver>_v<sdk_ver>.run
    ./ZED_SDK_Tegra_L4T<os_ver>_v<sdk_ver>.run
    How to Install ROS 2 Foxy on Jetson AGX Orin
    ROS 2 Foxy
    Install ROS 2 Foxy
    Make sure you have a locale that supports UTF-8
    locale  # check for UTF-8
    sudo apt update && sudo apt install locales
    export LANG=en_US.UTF-8
    locale  # verify settings
    sudo apt update && sudo apt install curl gnupg2 lsb-release
    sudo apt update
    sudo apt upgrade
    Bash shell
    echo "source /opt/ros/foxy/setup.bash" >> ~/.bashrc
    source ~/.bashrc
    zsh shell
    echo "source /opt/ros/foxy/setup.zsh" >> ~/.zshrc
    source ~/.zshrc
    Initialize rosdep
    sudo rosdep init
    rosdep update
    Install the ZED ROS 2 Wrapper
    mkdir -p ~/ros2_ws/src
    cd ~/ros2_ws/src/
    git clone --recursive https://github.com/stereolabs/zed-ros2-wrapper.git
    cd ..
    Bash shell
    cd ~/ros2_ws/
    source ~/.bashrc
    zsh shell
    cd ~/ros2_ws/
    echo "source $(pwd)/install/local_setup.zsh" >> ~/.zshrc
    source ~/.zshrc
    Install the examples and tutorial
    cd ~/ros2_ws/src/
    cd ../
    rosdep install --from-paths src --ignore-src -r -y colcon build --symlink-install --cmake-args=-DCMAKE_BUILD_TYPE=Release
    source ~/.bashrc
    Known issues with ROS 2 Foxy
    Image Transport and topic subscriptions
    There is an issue with the default version of the function CameraPublisher::getNumSubscribers available in the binary version of the image_transport package preventing the correct counting of the number of nodes subscribing one of the topics published by an image_transport::CameraPublisher object.
    We suggest installing the version v3.0.0, published on 2021-05-26, that contains the fix for this issue. Please note that earlier or later versions do not work as expected.
    cd ~/ros2_ws/src # Access the source folder of your colcon workspace
    git clone https://github.com/ros-perception/image_common.git -b ros2 # clone the "ros" branch of the "image_common" repository
    cd <colcon_workspace> # Go back to the root of your colcon workspace
    colcon build --symlink-install # Compile everything and install
    Image Transport Plugins and compressed topics
    The image_transport_plugins package is not correctly working with ROS 2 Foxy (see here, here, here, and here). We suggest you remove it to avoid many annoying warning messages until the ROS 2 developers fix it or use this workaround:
    Create a Docker image with ROS 2 for Jetson AGX Orin™
    Create the Dockerfile
    Dockerfile Download
    Choose the right NVIDIA container to create the Docker image and install the ZED SDK
    ARG L4T_MINOR_VERSION=1.0
    ARG ZED_SDK_MAJOR=3
    ARG ZED_SDK_MINOR=7
    ARG JETPACK_MAJOR=5
    ARG JETPACK_MINOR=0
    ENV LOGNAME root
    # Install dependencies
        rm -rf /var/lib/apt/lists/*
    RUN ln -sf /usr/lib/aarch64-linux-gnu/tegra/libv4l2.so.0 /usr/lib/aarch64-linux-gnu/libv4l2.so
    Install ROS 2 Foxy
    Since the latest Jetson Linux is based on Ubuntu 20.04, ROS 2 Foxy can be directly installed by using the binaries. Set up the system and install ROS-Base which is the bare bones with the minimum required packages and no GUI tools, if you choose to install ROS 2 with GUI tools, demos, and tutorials you can replace ros-foxy-ros-base with ros-foxy-desktop.
    #ROS system setup
    ENV LANG en_US.UTF-8
    ENV LC_ALL en_US.UTF-8
    ENV ROS_DISTRO foxy
        apt-get clean
    Setup the ROS Workspace
    #Setup ROS Workspace
    ENV ROS_WS /opt/ros2_ws
        cd ${ROS_WS}/ && \
        . install/local_setup.sh
    Install ZED ROS 2 Wrapper
    Install the zed-ros2-wrapper package from Github. Remember to automatically source the environment setup script every time a new shell is launched by including source commands into the file /root/.bashrc.
        . /opt/ros/foxy/setup.sh && \
    RUN apt-get autoremove
    WORKDIR ${ROS_WS}
    Note that the ZED ROS 2 wrapper requires the CUDA compiler during docker build. You must then modify the file /etc/docker/daemon.json before building the container:
    Modify the file and save it:
      "runtimes": {
        "nvidia": {
          "runtimeArgs": []
      "default-runtime": "nvidia"
    You must restart the Docker service before building the container to apply:
    sudo systemctl daemon-reload
    sudo systemctl restart docker
    Build the Image from the Dockerfile
    sudo usermod -aG docker $USER
    Run the Docker Image
    docker run -it --rm --net=host --runtime nvidia -e DISPLAY=$DISPLAY -e NVIDIA_DRIVER_CAPABILITIES=all -v /tmp/.X11-unix/:/tmp/.X11-unix -v ${HOME}/.Xauthority:/root/.Xauthority --privileged -e DISPLAY=$DISPLAY --gpus all zed-3.7-ros2-foxy-jetson-jp5.0.2
    You can now start using Stereolabs ZED cameras with ROS 2 on a Docker container.
    If you need help or you have a question. you can contact us by email or write a post on our forum.
