SensorsConfiguration Struct Reference
Structure containing information about all the sensors available in the current device. More...
bool isSensorAvailable (const sl::SENSOR_TYPE &sensor_type)
 Checks if a sensor is available on the device. More...
Attributes
unsigned int firmware_version = 0
 Firmware version of the sensor module. More...
sl::Transform camera_imu_transform
 IMU to left camera transform matrix. More...
sl::Transform imu_magnetometer_transform
 Magnetometer to IMU transform matrix. More...
sl::SensorParameters accelerometer_parameters
 Configuration of the accelerometer. More...
sl::SensorParameters gyroscope_parameters
 Configuration of the gyroscope. More...
sl::SensorParameters magnetometer_parameters
 Configuration of the magnetometer. More...
sl::SensorParameters barometer_parameters
 Configuration of the barometer. More...
Information about the camera sensors is available in the sl::CameraInformation struct returned by sl::Camera.getCameraInformation().
Note
This structure is meant to be used as a read-only container.
Editing any of its fields will not impact the ZED SDK.
◆ isSensorAvailable()
bool isSensorAvailable ( const sl::SENSOR_TYPE &  sensor_type)
Parameters
sensor_type: Sensor type to check.
Returns
true if the sensor is available on the device, otherwise false.
Variables
◆ firmware_version
Note
0 if no sensors are available (sl::MODEL::ZED).
◆ camera_imu_transform
Note
It contains the rotation and translation between the IMU frame and camera frame.
◆ imu_magnetometer_transform
Note
It contains rotation and translation between IMU frame and magnetometer frame.
◆ accelerometer_parameters
◆ gyroscope_parameters
◆ magnetometer_parameters
◆ barometer_parameters
