RegionOfInterestParameters Struct Reference
Attributes
float depth_far_threshold_meters = 2.5
 Filtering how far object in the ROI should be considered, this is useful for a vehicle for instance. More...
float image_height_ratio_cutoff = 0.5
 By default consider only the lower half of the image, can be useful to filter out the sky. More...
std::unordered_set< MODULE > auto_apply_module = {MODULE::ALL}
 Once computed the ROI computed will be automatically applied. More...
Variables
◆ depth_far_threshold_meters
Default: 2.5 meters
◆ image_height_ratio_cutoff
Default: 0.5, correspond to the lower half of the image
◆ auto_apply_module
std::unordered_set<MODULE> auto_apply_module = {MODULE::ALL}
Default: All modules
