PositionalTrackingFusionParameters Class Reference
Holds the options used for initializing the positional tracking fusion module. More...
bool operator== (const PositionalTrackingFusionParameters &param1) const
bool operator!= (const PositionalTrackingFusionParameters &param1) const
Attributes
bool enable_GNSS_fusion = false
 This attribute is responsible for enabling or not GNSS positional tracking fusion. More...
GNSSCalibrationParameters gnss_calibration_parameters
 Control the VIO / GNSS calibration process.
More...
Transform base_footprint_to_world_transform
 Position and orientation of the base footprint with respect to the user world. This transform represents a basis change from base footprint coordinate frame to user world coordinate frame. More...
Transform base_footprint_to_baselink_transform
 Position and orientation of the base footprint with respect to the baselink. This transform represents a basis change from base footprint coordinate frame to baselink coordinate frame. More...
bool set_gravity_as_origin = false
 Whether to override 2 of the 3 rotations from base_footprint_to_world_transform using the IMU gravity. More...
◆ save()
bool save ( String  filename,
) const
Parameters
Returns
Warning
◆ load()
bool load ( String  filename,
Parameters
Returns
◆ encode()
) const
Parameters
Returns
◆ decode()
Parameters
Returns
◆ operator==()
bool operator== ( const PositionalTrackingFusionParameters &  param1) const
Parameters
PositionalTrackingFusionParametersto compare
Returns
◆ operator!=()
bool operator!= ( const PositionalTrackingFusionParameters &  param1) const
Parameters
Returns
Variables
◆ enable_GNSS_fusion
◆ gnss_calibration_parameters
◆ base_footprint_to_world_transform
Note
base footprint is the coordinate frame attached to the projected baselink coordinate frame on the ground. It is generally a constant offset between baselink and the ground. Fusion uses the base footprint coordinate frame to determine where is the ground with respect to the tracked baselink position and orientation. baselink is the root coordinate frame of the robot. Fusion configuration file must give the position and orientation of each camera with respect to the baselink
◆ base_footprint_to_baselink_transform
Note
This transform is used by the Fusion to determine where is the ground with respect to the baselink coordinate frame which is the root coordinate frame of Fusion.
◆ set_gravity_as_origin
