ObjectDetectionRuntimeParameters Class Reference
Structure containing a set of runtime parameters for the object detection module. More...
 ObjectDetectionRuntimeParameters (const float detection_confidence_threshold=20.f, const std::vector< OBJECT_CLASS > &object_class_filter=std::vector< OBJECT_CLASS >{}, const std::map< OBJECT_CLASS, float > &object_class_detection_confidence_threshold=std::map< OBJECT_CLASS, float >{})
 Default constructor. More...
bool save (const String &filename, SERIALIZATION_FORMAT format=SERIALIZATION_FORMAT::JSON) const
bool load (const String &filename, SERIALIZATION_FORMAT format=SERIALIZATION_FORMAT::JSON)
bool operator== (const ObjectDetectionRuntimeParameters &param1) const
bool operator!= (const ObjectDetectionRuntimeParameters &param1) const
Attributes
 Confidence threshold. More...
std::vector< OBJECT_CLASS > object_class_filter
 Defines which object types to detect and track. More...
std::map< OBJECT_CLASS, float > object_class_detection_confidence_threshold
 Map of confidence thresholds for each class (can be empty for some classes). More...
Note
Constructor and Destructor
◆ ObjectDetectionRuntimeParameters()
ObjectDetectionRuntimeParameters ( const float  detection_confidence_threshold = 20.f,
const std::vector< OBJECT_CLASS > &  object_class_filter = std::vector< OBJECT_CLASS >{},
const std::map< OBJECT_CLASS, float > &  object_class_detection_confidence_threshold = std::map< OBJECT_CLASS, float >{}
Parameters
detection_confidence_thresholdConfidence threshold.
object_class_filterObject class filter.
object_class_detection_confidence_thresholdMap of confidence threshold per classes.
◆ save()
bool save ( const String &  filename,
) const
Parameters
Returns
Warning
◆ load()
bool load ( const String &  filename,
Parameters
Returns
◆ encode()
) const
Parameters
Returns
◆ decode()
Parameters
Returns
◆ operator==()
bool operator== ( const ObjectDetectionRuntimeParameters &  param1) const
Comparison operator ==
Parameters
ObjectDetectionRuntimeParametersto compare
Returns
◆ operator!=()
bool operator!= ( const ObjectDetectionRuntimeParameters &  param1) const
Comparison operator !=
Parameters
Returns
Variables
◆ detection_confidence_threshold
From 1 to 100, with 1 meaning a low threshold, more uncertain objects and 99 very few but very precise objects.
Default: 20.f
Note
If the scene contains a lot of objects, increasing the confidence can slightly speed up the process, since every object instance is tracked.
detection_confidence_threshold is used as a fallback when sl::ObjectDetectionRuntimeParameters.object_class_detection_confidence_threshold is partially set.
◆ object_class_filter
std::vector<OBJECT_CLASS> object_class_filter
Default: {} (all classes are tracked)
Note
Fewer object types can slightly speed up the process since every object is tracked.
Will output only the selected classes.
In order to get all the available classes, the filter vector must be empty :
Definition: Camera.hpp:1645
To select a set of specific object classes, like vehicles, persons and animals for instance:
◆ object_class_detection_confidence_threshold
std::map<OBJECT_CLASS, float> object_class_detection_confidence_threshold
Note
sl::ObjectDetectionRuntimeParameters.detection_confidence_threshold will be taken as fallback/default value.
