ObjectDetectionFusionParameters Class Reference
Holds the options used to initialize the object detection module of the Fusion. More...
bool save (const String &filename, const SERIALIZATION_FORMAT format=SERIALIZATION_FORMAT::JSON) const
bool load (const String &filename, const SERIALIZATION_FORMAT format=SERIALIZATION_FORMAT::JSON)
bool encode (String &serialized_content, const SERIALIZATION_FORMAT format=SERIALIZATION_FORMAT::JSON) const
bool decode (const String &serialized_content, const SERIALIZATION_FORMAT format=SERIALIZATION_FORMAT::JSON)
bool operator== (const ObjectDetectionFusionParameters &params) const
bool operator!= (const ObjectDetectionFusionParameters &params) const
Attributes
bool enable_tracking = true
 Defines if the object detection will track objects across images flow. More...
◆ save()
bool save ( const String &  filename,
const SERIALIZATION_FORMAT  format = SERIALIZATION_FORMAT::JSON
) const
Parameters
Returns
Warning
◆ load()
bool load ( const String &  filename,
Parameters
Returns
◆ encode()
) const
Parameters
Returns
◆ decode()
Parameters
Returns
◆ operator==()
bool operator== ( const ObjectDetectionFusionParameters &  params) const
Parameters
ObjectDetectionFusionParametersto compare
Returns
◆ operator!=()
bool operator!= ( const ObjectDetectionFusionParameters &  params) const
Parameters
Returns
Variables
◆ enable_tracking
