BodyTrackingFusionRuntimeParameters Class Reference
Holds the options used to change the behavior of the body tracking module at runtime. More...
bool operator== (const BodyTrackingFusionRuntimeParameters &param1) const
bool operator!= (const BodyTrackingFusionRuntimeParameters &param1) const
Attributes
int skeleton_minimum_allowed_keypoints = -1
 If the fused skeleton has less than skeleton_minimum_allowed_keypoints keypoints, it will be discarded. More...
int skeleton_minimum_allowed_camera = -1
 If a skeleton was detected in less than skeleton_minimum_allowed_camera cameras, it will be discarded. More...
float skeleton_smoothing = 0.f
 This value controls the smoothing of the tracked or fitted fused skeleton. More...
◆ save()
bool save ( String  filename,
) const
Parameters
Returns
Warning
◆ load()
bool load ( String  filename,
Parameters
Returns
◆ encode()
) const
Parameters
Returns
◆ decode()
Parameters
Returns
◆ operator==()
bool operator== ( const BodyTrackingFusionRuntimeParameters &  param1) const
Parameters
BodyTrackingFusionRuntimeParametersto compare
Returns
◆ operator!=()
bool operator!= ( const BodyTrackingFusionRuntimeParameters &  param1) const
Parameters
Returns
Variables
◆ skeleton_minimum_allowed_keypoints
◆ skeleton_minimum_allowed_camera
◆ skeleton_smoothing
It is ranged from 0 (low smoothing) and 1 (high smoothing).
