BodyTrackingFusionParameters Class Reference
Holds the options used to initialize the body tracking module of the Fusion. More...
bool operator== (const BodyTrackingFusionParameters &param1) const
bool operator!= (const BodyTrackingFusionParameters &param1) const
Attributes
bool enable_tracking = true
 Defines if the object detection will track objects across images flow. More...
bool enable_body_fitting = false
 Defines if the body fitting will be applied. More...
◆ save()
bool save ( String  filename,
) const
Parameters
Returns
Warning
◆ load()
bool load ( String  filename,
Parameters
Returns
◆ encode()
) const
Parameters
Returns
◆ decode()
Parameters
Returns
◆ operator==()
bool operator== ( const BodyTrackingFusionParameters &  param1) const
Parameters
BodyTrackingFusionParametersto compare
Returns
◆ operator!=()
bool operator!= ( const BodyTrackingFusionParameters &  param1) const
Parameters
Returns
Variables
◆ enable_tracking
◆ enable_body_fitting
Note
If you enable it and the camera provides data as BODY_18 the fused body format will be BODY_34.
