BatchParameters Class Reference
Structure containing a set of parameters for batch object detection. More...
 BatchParameters (bool enable=false, float id_retention_time=240.f, float batch_duration=2.f)
 Default constructor. More...
bool operator== (const BatchParameters &param1) const
bool operator!= (const BatchParameters &param1) const
Attributes
bool enable = false
 Whether to enable the batch option in the object detection module. More...
float id_retention_time = 240
 Max retention time in seconds of a detected object. More...
float latency = 2.f
 Trajectories will be output in batch with the desired latency in seconds. More...
Note
Constructor and Destructor
◆ BatchParameters()
BatchParameters ( bool  enable = false,
float  id_retention_time = 240.f,
float  batch_duration = 2.f
All the parameters are set to their default values.
◆ save()
bool save ( String  filename,
) const
Parameters
Returns
Warning
◆ load()
bool load ( String  filename,
Parameters
Returns
◆ encode()
) const
Parameters
Returns
◆ decode()
Parameters
Returns
◆ operator==()
bool operator== ( const BatchParameters &  param1) const
Comparison operator ==
Parameters
BatchParametersto compare
Returns
◆ operator!=()
bool operator!= ( const BatchParameters &  param1) const
Comparison operator !=
Parameters
Returns
Variables
◆ enable
bool enable = false
Batch queueing system provides:
  • deep-learning based re-identification
  • trajectory smoothing and filtering
Note
To activate this option, enable must be set to true.
◆ id_retention_time
After this time, the same object will mostly have a different id.
◆ latency
float latency = 2.f
During this waiting time, re-identification of objects is done in the background.
Note
Specifying a short latency will limit the search (falling in timeout) for previously seen object ids but will be closer to real time output.
Specifying a long latency will reduce the change of timeout in re-identification but increase difference with live output.
