Classes | |
| class | PositionalTrackingParameters |
| Class containing a set of parameters for the positional tracking module initialization. More... | |
| struct | Pose |
| Structure containing positional tracking data giving the position and orientation of the camera in 3D space. More... | |
| struct | RegionOfInterestParameters |
| Structure containing a set of parameters for the region of interest. More... | |
| struct | PositionalTrackingStatus |
| Lists the different status of positional tracking. More... | |
Enumerations | |
| enum class | POSITIONAL_TRACKING_STATE |
| Lists the different states of positional tracking. More... | |
| enum class | ODOMETRY_STATUS |
| Report the status of current odom tracking. More... | |
| enum class | SPATIAL_MEMORY_STATUS |
| Report the status of current map tracking. More... | |
| enum class | POSITIONAL_TRACKING_FUSION_STATUS |
| Report the status of the positional tracking fusion. More... | |
| enum class | POSITIONAL_TRACKING_MODE |
| Lists the mode of positional tracking that can be used. More... | |
| enum class | REFERENCE_FRAME |
| Lists possible types of position matrix used to store camera path and pose. More... | |
| enum class | TRACKING_FRAME |
| Part of the ZED (left/right sensor, center) that's considered its center for tracking purposes. More... | |
strong |
| Enumerator | |
| SEARCHING | \warn DEPRECATED: This state is no longer in use. |
| OK | The positional tracking is working normally. |
| OFF | The positional tracking is not enabled. |
| FPS_TOO_LOW | The effective FPS is too low to give proper results for motion tracking. |
| SEARCHING_FLOOR_PLANE | The camera is searching for the floor plane to locate itself with respect to it. |
| UNAVAILABLE | The tracking module was unable to perform tracking from the previous frame to the current frame. |
strong |
strong |
strong |
strong |
strong |
| Enumerator | |
| WORLD | The transform of sl.Pose will contain the motion with reference to the world frame (previously called sl.PATH). |
| CAMERA | The transform of sl.Pose will contain the motion with reference to the previous camera frame (previously called sl.POSE). |
strong |
