Class containing a set of parameters for the positional tracking module initialization. More...
Attributes | |
| Quaternion | initialWorldRotation = Quaternion.Identity |
| Rotation of the camera in the world frame when the camera is started. More... | |
| Vector3 | initialWorldPosition = Vector3.Zero |
| Position of the camera in the world frame when the camera is started. More... | |
| bool | enableAreaMemory = true |
| Whether the camera can remember its surroundings. More... | |
| bool | enablePoseSmothing = false |
| Whether to enable smooth pose correction for small drift correction. More... | |
| bool | setFloorAsOrigin = false |
| Initializes the tracking to be aligned with the floor plane to better position the camera in space. More... | |
| bool | setAsStatic = false |
| Whether to define the camera as static. More... | |
| bool | enableIMUFusion = true |
| Whether to enable the IMU fusion. More... | |
| float | depthMinRange = -1f |
| Minimum depth used by the ZED SDK for positional tracking. More... | |
| bool | setGravityAsOrigin = true |
| Whether to override 2 of the 3 components from initialWorldRotation using the IMU gravity. More... | |
| string | areaFilePath = "" |
| Path of an area localization file that describes the surroundings (saved from a previous tracking session). More... | |
| sl.POSITIONAL_TRACKING_MODE | mode = sl.POSITIONAL_TRACKING_MODE.GEN_1 |
| Positional tracking mode used. More... | |
| Quaternion initialWorldRotation = Quaternion.Identity |
| Vector3 initialWorldPosition = Vector3.Zero |
| bool enableAreaMemory = true |
This helps correct positional tracking drift and can be helpful for positioning different cameras relative to one other in space.
| bool enablePoseSmothing = false |
| bool setFloorAsOrigin = false |
| bool setAsStatic = false |
If true, it will not move in the environment. This allows you to set its position using initialWorldPosition and initialWorldRotation.
All ZED SDK functionalities requiring positional tracking will be enabled without additional computation.
sl.Camera.GetPosition() will return the values set as initialWorldPosition and initialWorldRotation.
| bool enableIMUFusion = true |
When set to false, only the optical odometry will be used.
| float depthMinRange = -1f |
It may be useful for example if any steady objects are in front of the camera and may perturb the positional tracking algorithm.
Default: -1 (no minimum depth)
| bool setGravityAsOrigin = true |
| string areaFilePath = "" |
Can be used to improve accuracy in some types of scene at the cost of longer runtime.
