| Enumerator |
| GNSS_DATA_COVARIANCE_MUST_VARY | Ingested covariance data must vary between ingest.
| BODY_FORMAT_MISMATCH | The senders are using different body formats.
Consider changing them.
| MODULE_NOT_ENABLED | The following module was not enabled.
| SOURCE_MISMATCH | Some sources are provided by SVO and others by LIVE stream.
| CONNECTION_TIMED_OUT | Connection timed out. Unable to reach the sender.
Verify the sender's IP/port.
| MEMORY_ALREADY_USED | Intra-process shared memory allocation issue.
Multiple connections to the same data.
| INVALID_IP_ADDRESS | The provided IP address format is incorrect.
Please provide the IP in the format 'a.b.c.d', where (a, b, c, d) are numbers between 0 and 255.
| FAILURE | Standard code for unsuccessful behavior.
| SUCCESS | Standard code for successful behavior.
| FUSION_INCONSISTENT_FPS | Significant differences observed between sender's FPS.
| FPS_TOO_LOW | At least one sender has an FPS lower than 10 FPS.
| INVALID_TIMESTAMP | Problem detected with the ingested timestamp.
Sample data will be ignored.
| INVALID_COVARIANCE | Problem detected with the ingested covariance.
| NO_NEW_DATA_AVAILABLE | All data from all sources has been consumed.
No new data is available for processing.
