Class that store externally detected objects with mask. More...
Functions | |
| CustomMaskObjectData () | |
| Default constructor. More... | |
Attributes | |
| String | unique_object_id |
| Unique id to help identify and track AI detections. More... | |
| std::vector< sl::uint2 > | bounding_box_2d |
| 2D bounding box of the object represented as four 2D points starting at the top left corner and rotation clockwise. More... | |
| int | label |
| Object label. More... | |
| float | probability |
| Detection confidence value of the object. More... | |
| bool | is_grounded = true |
| Provide hypothesis about the object movements (degrees of freedom or DoF) to improve the object tracking. More... | |
| bool | is_static = false |
| Provide hypothesis about the object staticity to improve the object tracking. More... | |
| float | tracking_timeout = -1.F |
| Maximum tracking time threshold (in seconds) before dropping the tracked object when unseen for this amount of time. By default, let the tracker decide internally based on the internal sub class of the tracked object. Only valid for static object. More... | |
| float | tracking_max_dist = -1.F |
| Maximum tracking distance threshold (in meters) before dropping the tracked object when unseen for this amount of meters. By default, do not discard tracked object based on distance. Only valid for static object. More... | |
| sl::Mat | box_mask |
| 2D mask of the object inside its bounding box. More... | |
The objects can be ingested with sl::Camera.ingestCustomMaskObjects() to extract 3D and tracking information over time.
| String unique_object_id |
It can be either generated externally, or by using generate_unique_id() or left empty.
| std::vector<sl::uint2> bounding_box_2d |
[0, 0] is the top left corner. | int label |
Object label.
This information is passed-through and can be used to improve object tracking.
| float probability |
[0-1]. | bool is_grounded = true |
| bool is_static = false |
| float tracking_timeout = -1.F |
| float tracking_max_dist = -1.F |
| sl::Mat box_mask |
