CameraIdentifier Class Reference
Used to identify a specific camera in the Fusion API. More...
 CameraIdentifier ()
 CameraIdentifier (uint64_t sn_)
sl::String get () const
bool save (const String &filename, const SERIALIZATION_FORMAT format=SERIALIZATION_FORMAT::JSON) const
bool load (const String &filename, const SERIALIZATION_FORMAT format=SERIALIZATION_FORMAT::JSON)
bool encode (String &serialized_content, const SERIALIZATION_FORMAT format=SERIALIZATION_FORMAT::JSON) const
bool decode (const String &serialized_content, const SERIALIZATION_FORMAT format=SERIALIZATION_FORMAT::JSON)
Attributes
uint64_t sn
Constructor and Destructor
◆ CameraIdentifier() [1/2]
CameraIdentifier ( )
inline
◆ CameraIdentifier() [2/2]
CameraIdentifier ( uint64_t  sn_)
inline
◆ get()
sl::String get ( ) const
inline
◆ save()
bool save ( const String &  filename,
const SERIALIZATION_FORMAT  format = SERIALIZATION_FORMAT::JSON
) const
Parameters
Returns
Warning
◆ load()
bool load ( const String &  filename,
Parameters
Returns
◆ encode()
) const
Parameters
Returns
◆ decode()
Parameters
Returns
Variables
◆ sn
uint64_t sn
Referenced by sl::operator!=(), and sl::operator==().
