Structure containing a set of parameters for the spatial mapping module. More...
Data Fields | |
| float | resolution_meter |
| Spatial mapping resolution in meters. More... | |
| float | range_meter |
| Depth range in meters. More... | |
| bool | save_texture |
| Whether to save the texture. More... | |
| bool | use_chunk_only |
| Whether to only use chunks. More... | |
| int | max_memory_usage |
| The maximum CPU memory (in MB) allocated for the meshing process. More... | |
| bool | reverse_vertex_order |
| Whether to inverse the order of the vertices of the triangles. More... | |
| enum SL_SPATIAL_MAP_TYPE | map_type |
| The type of spatial map to be created. More... | |
| int | stability_counter |
| Control the integration rate of the current depth into the mapping process. More... | |
| float SL_SpatialMappingParameters::resolution_meter |
Default: 0.05f
| float SL_SpatialMappingParameters::range_meter |
Can be different from the value set by SL_InitParameters.depth_maximum_distance.
| bool SL_SpatialMappingParameters::save_texture |
If set to true, you will be able to apply the texture to your mesh after it is created.
Default: false
| bool SL_SpatialMappingParameters::use_chunk_only |
If set to false, you will ensure consistency between the mesh and its inner chunk data.
Default: false
| int SL_SpatialMappingParameters::max_memory_usage |
Default: 2048
| bool SL_SpatialMappingParameters::reverse_vertex_order |
If your display process does not handle front and back face culling, you can use this to correct it.
Default: false
| enum SL_SPATIAL_MAP_TYPE SL_SpatialMappingParameters::map_type |
This dictates the format that will be used for the mapping (e.g. mesh, point cloud).
See SL_SPATIAL_MAP_TYPE.
| int SL_SpatialMappingParameters::stability_counter |
This parameter controls how many times a stable 3D points should be seen before it is integrated into the spatial mapping.
Default: 0 (this will define the stability counter based on the mesh resolution, the higher the resolution, the higher the stability counter)
