We highly recommend upgrading your SDK and camera firmware. To do so, install the latest and run ZED Explorer. The tool will detect your firmware version and prompt you to upgrade.
Recording uncompressed stereo video at up to 60FPS in 2560×720 resolution is a challenge for many platforms. To reduce the load on your hard drive, we provide two compression modes: Lossless and Lossy. These two modes now perform compression in parallel with I/O operations, improving throughput by 40-50%.
For a complete listing of changes, see the release notes.
-The ZED Team
