The performance of the new Jetson AGX Orin™ unlocks capabilities such as processing 3D data coming from multiple ZED 2i Depth Cameras, making it the ideal combination for autonomous robotics and edge analytics solutions. It is now available for purchase at .
NVIDIA Jetson AGX Orin
cd Downloads chmod +x ZED_SDK_Tegra_L4T<os_ver>_v<sdk_ver>.run ./ZED_SDK_Tegra_L4T<os_ver>_v<sdk_ver>.run
ROS 2 Foxy
Make sure you have a locale that supports UTF-8
locale # check for UTF-8 sudo apt update && sudo apt install locales sudo locale-gen en_US en_US.UTF-8 sudo update-locale LC_ALL=en_US.UTF-8 LANG=en_US.UTF-8 export LANG=en_US.UTF-8 locale # verify settings
sudo apt update && sudo apt install curl gnupg2 lsb-release sudo curl -sSL https://raw.githubusercontent.com/ros/rosdistro/master/ros.key -o /usr/share/keyrings/ros-archive-keyring.gpg
sudo apt update
sudo apt upgrade
Bash shell
echo "source /opt/ros/foxy/setup.bash" >> ~/.bashrc source ~/.bashrc
zsh shell
echo "source /opt/ros/foxy/setup.zsh" >> ~/.zshrc source ~/.zshrc
Initialize rosdep
sudo rosdep init rosdep update
mkdir -p ~/ros2_ws/src cd ~/ros2_ws/src/ git clone --recursive https://github.com/stereolabs/zed-ros2-wrapper.git cd .. rosdep install --from-paths src --ignore-src -r -y colcon build --symlink-install --cmake-args=-DCMAKE_BUILD_TYPE=Release
Bash shell
cd ~/ros2_ws/ echo source $(pwd)/install/local_setup.bash >> ~/.bashrc source ~/.bashrc
zsh shell
cd ~/ros2_ws/ echo "source $(pwd)/install/local_setup.zsh" >> ~/.zshrc source ~/.zshrc
cd ~/ros2_ws/src/ git clone https://github.com/stereolabs/zed-ros2-examples.git cd ../ rosdep install --from-paths src --ignore-src -r -y colcon build --symlink-install --cmake-args=-DCMAKE_BUILD_TYPE=Release source ~/.bashrc
There is an issue with the default version of the function CameraPublisher::getNumSubscribers available in the binary version of the image_transport package preventing the correct counting of the number of nodes subscribing one of the topics published by an image_transport::CameraPublisher object.
We suggest installing the version v3.0.0, published on 2021-05-26, that contains the fix for this issue. Please note that earlier or later versions do not work as expected.
cd ~/ros2_ws/src # Access the source folder of your colcon workspace git clone https://github.com/ros-perception/image_common.git -b ros2 # clone the "ros" branch of the "image_common" repository cd <colcon_workspace> # Go back to the root of your colcon workspace colcon build --symlink-install # Compile everything and install
The image_transport_plugins package is not correctly working with ROS 2 Foxy (see here, here, here, and here). We suggest you remove it to avoid many annoying warning messages until the ROS 2 developers fix it or use this workaround:
ARG L4T_MINOR_VERSION=1.0
ARG ZED_SDK_MAJOR=3
ARG ZED_SDK_MINOR=7
ARG JETPACK_MAJOR=5
ARG JETPACK_MINOR=0
ENV LOGNAME root
# Install dependencies
rm -rf /var/lib/apt/lists/*
RUN ln -sf /usr/lib/aarch64-linux-gnu/tegra/libv4l2.so.0 /usr/lib/aarch64-linux-gnu/libv4l2.soSince the latest Jetson Linux is based on Ubuntu 20.04, ROS 2 Foxy can be directly installed by using the binaries. Set up the system and install ROS-Base which is the bare bones with the minimum required packages and no GUI tools, if you choose to install ROS 2 with GUI tools, demos, and tutorials you can replace ros-foxy-ros-base with ros-foxy-desktop.
#ROS system setup
ENV LANG en_US.UTF-8
ENV LC_ALL en_US.UTF-8
ENV ROS_DISTRO foxy
apt-get clean
Setup the ROS Workspace
#Setup ROS Workspace
ENV ROS_WS /opt/ros2_ws
cd ${ROS_WS}/ && \
. install/local_setup.shInstall the zed-ros2-wrapper package from Github. Remember to automatically source the environment setup script every time a new shell is launched by including source commands into the file /root/.bashrc.
. /opt/ros/foxy/setup.sh && \
RUN apt-get autoremove
WORKDIR ${ROS_WS}Note that the ZED ROS 2 wrapper requires the CUDA compiler during docker build. You must then modify the file /etc/docker/daemon.json before building the container:
Modify the file and save it:
"runtimes": {
"nvidia": {
"runtimeArgs": []
"default-runtime": "nvidia"
}You must restart the Docker service before building the container to apply:
sudo systemctl daemon-reload sudo systemctl restart docker
sudo usermod -aG docker $USER
docker run -it --rm --net=host --runtime nvidia -e DISPLAY=$DISPLAY -e NVIDIA_DRIVER_CAPABILITIES=all -v /tmp/.X11-unix/:/tmp/.X11-unix -v ${HOME}/.Xauthority:/root/.Xauthority --privileged -e DISPLAY=$DISPLAY --gpus all zed-3.7-ros2-foxy-jetson-jp5.0.2You can now start using Stereolabs ZED cameras with ROS 2 on a Docker container.
