H.264/H.265 hardware encoding is supported on Jetson Nano, TX2 or Xavier. From remote streaming to video recording, learn more about the encoding capabilities of your Jetson.
| Board | Family | H.264 | H.264 | H.265 | H.265 |
| Jetson Nano | Maxwell | YES | YES | YES | YES |
 | 1x | 4x | 1x | 4x |
| Jetson TX2 |
| BOARD | FAMILY | H.264 | H.264 | H.265 | H.265 |
 | 2x | 8x | 2x | 8x |
| Jetson TX2 | Pascal |
Pascal
| YES |
| YES |
| YES |
| YES |
 | 3x | 14x | 3x | 8x |
| Jetson Xavier NX | Volta | YES | YES | YES | YES |
 | 2x | 14x | 2x | 14x |
| Jetson Xavier | Volta | YES | YES | YES | YES |
 | 8x | 30x | 8x | 32x |
YES
| YES |
| YES |
| YES |
 | 4x | 14x | 4x | 14x |
 | 2x | 16x | 4x | 32x |
 | 8x | 32x | 12x | 52x |
