NewsTutorials
Nov 17, 2015.
Stereo Video Passthrough for Oculus Rift
Note: This is for ZED SDK 1.0 only. Please see the latest SDK guides and documentation here.
  • Oculus Rift DK2
  • Windows 7 64 bits or later
  • ZED SDK and its dependencies (CUDA, OpenCV 3.1)
  • Oculus SDK 1.3.0 or later
  • GLEW
  • SDL
Overview
  • Code
  • Explanation
  • 1. Initialize SDL2, Oculus and OpenGL
  • 2. Initialize the ZED camera
  • 3. Create an Oculus swap texture set and frame buffer
  • 4. Create a mirror frame buffer for SDL2 window
  • 5. Configure the variables used by the Oculus compositor
  • 6. Initialize the shader and its variables
    • 6.1. Create the shader
    • 6.2. Convert ZED frames to Oculus frames
  • 7. Create the render loop
  • 8. Manage render timing
  • 9. Manage input events
  • 10. Render to the Oculus
    • 10.1. Grab ZED image and bind the frame buffer
    • 10.2. Render to each Oculus eye a ZED image
    • 10.3. Optimizing stereo visual comfort
    • 10.4. Submit the frame buffer to the rift
  • 11. Render to the SDL2 window
  • 12. Your application is ready
Code
Don’t forget to:
  • Set the CMake variable OCULUS_PATH with the path of your SDK (eg: “C:\ovr_sdk_win_0.8.0.0\OculusSDK”)
  • Set the CMake variable SDL_PATH with the path of the SDL2 library (eg: “C:\SDL2-2.0.3”)
  • Copy SDL2 and GLEW dll to the folder where the executable of the project has been generated.
Explanation
#include <iostream>
#include <Windows.h>
#include <GL/glew.h>
#include <stddef.h>
#include <SDL.h>
#include <SDL_syswm.h>
#include <OVR.h>
#include <OVR_CAPI.h>
#include <OVR_CAPI_GL.h>
#include <zed/Camera.hpp>
#include "Shader.hpp"
#define MAX_FPS 75
GLchar* OVR_ZED_VS =
	"#version 330 core
	uniform float hit;
	out vec2 b_coordTexture;
	void main()
		b_coordTexture = in_texCoord;
GLchar* OVR_ZED_FS =
	"#version 330 core
	in vec2 b_coordTexture;
	out vec4 out_color;
	void main()
// Initialize SDL2 context
SDL_Init(SDL_INIT_VIDEO);
// Initialize Oculus context
if (OVR_FAILURE(result))
	SDL_Quit();
	return -1;
ovrSession hmd;
ovrGraphicsLuid luid;
	ovr_Shutdown();
	SDL_Quit();
	return -1;
int winWidth = 1280;
int winHeight = 720;
// Create SDL2 Window
// Create OpenGL context
// Initialize GLEW
glewInit();
SDL_GL_SetSwapInterval(0);
// Initialize the ZED Camera
sl::zed::Camera* zed = 0;
	ovr_Destroy(hmd);
	ovr_Shutdown();
	SDL_DestroyWindow(window);
	SDL_Quit();
	delete zed;
	return -1;
GLuint zedTextureID_L, zedTextureID_R;
// Generate OpenGL texture for left images of the ZED camera
glGenTextures(1, &zedTextureID_L);
glBindTexture(GL_TEXTURE_2D, zedTextureID_L);
glTexImage2D(GL_TEXTURE_2D, 0, GL_RGBA, zedWidth, zedHeight, 0, GL_BGRA, GL_UNSIGNED_BYTE, NULL);
glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_MAG_FILTER, GL_LINEAR);
glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_MIN_FILTER, GL_NEAREST);
glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_WRAP_S, GL_REPEAT);
glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_WRAP_T, GL_REPEAT);
// Generate OpenGL texture for right images of the ZED camera
glGenTextures(1, &zedTextureID_R);
glBindTexture(GL_TEXTURE_2D, zedTextureID_R);
ovrSizei bufferSize;
else
	ovr_Destroy(hmd);
	ovr_Shutdown();
	SDL_Quit();
	delete zed;
	return -1;
GLuint fboID;
glGenFramebuffers(1, &fboID);
GLuint depthBuffID;
if (!OVR_SUCCESS(result))
GLuint mirrorFBOID;
glBindFramebuffer(GL_READ_FRAMEBUFFER, 0);
ovrLayerEyeFov ld;
ld.Header.Flags = ovrLayerFlag_TextureOriginAtBottomLeft | ovrLayerFlag_HeadLocked;   // Because OpenGL | Disable head tracking
	// Set the field of view
	// Set the pose matrix
viewScaleDesc.HmdToEyeViewOffset[1] = viewOffset[1];
// Create and compile the shader's sources
Shader shader(OVR_ZED_VS, OVR_ZED_FS);
// Compute the ZED image field of view with the ZED parameters
float zedFovH = atanf(zed->getImageSize().width / (zed->getParameters()->LeftCam.fx * 2.f)) * 2.f;
// Compute the Oculus' field of view with its parameters
float ovrFovH = (atanf(hmdDesc.DefaultEyeFov[0].LeftTan) + atanf(hmdDesc.DefaultEyeFov[0].RightTan));
// Compute the useful part of the ZED image
unsigned int usefulWidth = zed->getImageSize().width * ovrFovH / zedFovH;
// Compute the size of the final image displayed in the headset with the ZED image's aspect-ratio kept
unsigned int widthFinal = bufferSize.w / 2; unsigned int heightFinal = zed->getImageSize().height * widthFinal / usefulWidth;
// Convert this size to OpenGL viewport's frame's coordinates
float heightGL = (heightFinal) / (float)(bufferSize.h);
float widthGL = ((zed->getImageSize().width * (heightFinal / (float)zed->getImageSize().height)) / (float)widthFinal);
GLuint rectVBO[3];
glGenBuffers(1, &rectVBO[0]);
glGenBuffers(1, &rectVBO[1]);
glGenBuffers(1, &rectVBO[2]);
// Initialize hit value
float hit = 0.02f;
// Initialize a boolean that will be used to stop the application’s loop and another one to pause/unpause rendering
bool end = false;
bool refresh = true;
// SDL variable that will be used to store input events
SDL_Event events;
// Initialize time variables. They will be used to limit the number of frames rendered per second.
int time1 = 0, timePerFrame = 0;
int frameRate = (int)(1000 / MAX_FPS);
// Enable the shader
glUseProgram(shader.getProgramId());
// Bind the Vertex Buffer Objects of the rectangle that displays ZED images
// vertices
glEnableVertexAttribArray(Shader::ATTRIB_VERTICES_POS);
glVertexAttribPointer(Shader::ATTRIB_VERTICES_POS, 3, GL_FLOAT, GL_FALSE, 0, 0);
// indices
// texture coordinates
glEnableVertexAttribArray(Shader::ATTRIB_TEXTURE2D_POS);
glVertexAttribPointer(Shader::ATTRIB_TEXTURE2D_POS, 2, GL_FLOAT, GL_FALSE, 0, 0);
// Main loop
while (!end)
     // code...
// Disable all OpenGL buffer
glUseProgram(0);
glBindVertexArray(0);
glDeleteBuffers(3, rectVBO);
ovr_Destroy(hmd);
ovr_Shutdown();
SDL_Quit();
delete zed;
// quit
return 0;
if (timePerFrame < frameRate)
	timePerFrame = frameRate;
// Frame counter
static unsigned int c = 0;
// Chronometer
static unsigned int time = 0;
if (time > 1000)
	// Display FPS
	// Reset chronometer
	time = 0;
	// Reset frame counter
	c = 0;
time += timePerFrame;
c++;
// Start frame chronometer
time1 = SDL_GetTicks();
  • Key Q released: set end to true to exit the application
  • Key R released: reset hit to zero
  • Key C released: pause/unpause rendering
  • Mouse wheel: increase/decrease hit
	// If a key is released
	if (events.type == SDL_KEYUP)
		// If Q quit the application
			end = true;
		// If R reset the hit value
			hit = 0.0f;
			refresh = !refresh;
	// If the mouse wheel is used
		float s;
		hit += 0.005f * s;
// successful grab ZED image
// Increment the CurrentIndex to point to the next texture within the output swap texture set.
// CurrentIndex must be advanced round-robin fashion every time we draw a new frame
ptextureSet->CurrentIndex = (ptextureSet->CurrentIndex + 1) % ptextureSet->TextureCount;
// Get the current swap texture pointer
auto tex = reinterpret_cast<ovrGLTexture*>(&ptextureSet->Textures[ptextureSet->CurrentIndex]);
// Bind the frame buffer
glBindFramebuffer(GL_FRAMEBUFFER, fboID);
// Set its color layer 0 as the current swap texture
glFramebufferTexture2D(GL_FRAMEBUFFER, GL_COLOR_ATTACHMENT0, GL_TEXTURE_2D, tex->OGL.TexId, 0);
// Set its depth layer as our depth buffer
glFramebufferTexture2D(GL_FRAMEBUFFER, GL_DEPTH_ATTACHMENT, GL_TEXTURE_2D, depthBuffID, 0);
// Clear the frame buffer
glClear(GL_COLOR_BUFFER_BIT | GL_DEPTH_BUFFER_BIT);
glClearColor(0, 0, 0, 1);
for (int eye = 0; eye &amp;amp;amp;amp;lt; 2; eye++)
	// Bind the hit value
	// Draw the ZED image
  • Synchronization: Left and right images need to be perfectly synchronized
  • Image Matching: Left and right images need to be matched in terms of alignment, color, and optical characteristics
  • Depth Budget: This is the maximum amount of 3D depth in-front and behind the display that our eyes can support. If the depth budget is exceeded then viewers will find it increasingly uncomfortable to view the stereoscopic images.
10.4. Submit the frame buffer to the Rift
} // if (refresh)
	ovr_Destroy(hmd);
	ovr_Shutdown();
	SDL_Quit();
	delete zed;
	return -1;
// Copy the frame to the mirror buffer
// which will be drawn in the SDL2 image
glBindFramebuffer(GL_DRAW_FRAMEBUFFER, 0);
GLint w = mirrorTexture->OGL.Header.TextureSize.w;
GLint h = mirrorTexture->OGL.Header.TextureSize.h;
glBlitFramebuffer(0, h, w, 0,
			0, 0, w, h,
			GL_COLOR_BUFFER_BIT, GL_NEAREST);
// Swap the SDL2 window
SDL_GL_SwapWindow(window);
