if (!OVR_SUCCESS(result))
GLuint mirrorFBOID;
glBindFramebuffer(GL_READ_FRAMEBUFFER, 0);Here we configure the variables used by the Oculus compositor. As we disable the headset tracking, we set default values.
ovrLayerEyeFov ld;
ld.Header.Flags = ovrLayerFlag_TextureOriginAtBottomLeft | ovrLayerFlag_HeadLocked; // Because OpenGL | Disable head tracking
// Set the field of view
// Set the pose matrix
viewScaleDesc.HmdToEyeViewOffset[1] = viewOffset[1];We create and compile our shader.
// Create and compile the shader's sources Shader shader(OVR_ZED_VS, OVR_ZED_FS);
// Compute the ZED image field of view with the ZED parameters float zedFovH = atanf(zed->getImageSize().width / (zed->getParameters()->LeftCam.fx * 2.f)) * 2.f; // Compute the Oculus' field of view with its parameters float ovrFovH = (atanf(hmdDesc.DefaultEyeFov[0].LeftTan) + atanf(hmdDesc.DefaultEyeFov[0].RightTan)); // Compute the useful part of the ZED image unsigned int usefulWidth = zed->getImageSize().width * ovrFovH / zedFovH; // Compute the size of the final image displayed in the headset with the ZED image's aspect-ratio kept unsigned int widthFinal = bufferSize.w / 2; unsigned int heightFinal = zed->getImageSize().height * widthFinal / usefulWidth; // Convert this size to OpenGL viewport's frame's coordinates float heightGL = (heightFinal) / (float)(bufferSize.h); float widthGL = ((zed->getImageSize().width * (heightFinal / (float)zed->getImageSize().height)) / (float)widthFinal);
GLuint rectVBO[3];
glGenBuffers(1, &rectVBO[0]);
glGenBuffers(1, &rectVBO[1]);
glGenBuffers(1, &rectVBO[2]);
glBindBuffer(GL_ARRAY_BUFFER, 0);Now that we have the right format for our stereo images, let’s create the render loop that will display the images in the Rift.
// Initialize hit value float hit = 0.02f; // Initialize a boolean that will be used to stop the application’s loop and another one to pause/unpause rendering bool end = false; bool refresh = true; // SDL variable that will be used to store input events SDL_Event events; // Initialize time variables. They will be used to limit the number of frames rendered per second. int time1 = 0, timePerFrame = 0; int frameRate = (int)(1000 / MAX_FPS);
// Enable the shader glUseProgram(shader.getProgramId()); // Bind the Vertex Buffer Objects of the rectangle that displays ZED images // vertices glEnableVertexAttribArray(Shader::ATTRIB_VERTICES_POS); glBindBuffer(GL_ARRAY_BUFFER, rectVBO[0]); glVertexAttribPointer(Shader::ATTRIB_VERTICES_POS, 3, GL_FLOAT, GL_FALSE, 0, 0); // indices glBindBuffer(GL_ELEMENT_ARRAY_BUFFER, rectVBO[2]); // texture coordinates glEnableVertexAttribArray(Shader::ATTRIB_TEXTURE2D_POS); glBindBuffer(GL_ARRAY_BUFFER, rectVBO[1]); glVertexAttribPointer(Shader::ATTRIB_TEXTURE2D_POS, 2, GL_FLOAT, GL_FALSE, 0, 0);
// Main loop
while (!end)
// code...
// Disable all OpenGL buffer
glUseProgram(0);
glBindVertexArray(0);
glDeleteBuffers(3, rectVBO);
ovr_Destroy(hmd);
ovr_Shutdown();
SDL_DestroyWindow(window);
SDL_Quit();
delete zed;
// quit
return 0;During runtime, we need check if the previous frame has been rendered too fast. If it is the case, we pause the render loop to have a FPS value equal or inferior to MAX_FPS. For debug purposes, we also display the FPS value in the console every second. So let’s go back to the while loop and add the following lines.
if (timePerFrame < frameRate)
timePerFrame = frameRate;
// Frame counter
static unsigned int c = 0;
// Chronometer
static unsigned int time = 0;
if (time > 1000)
// Display FPS
// Reset chronometer
time = 0;
// Reset frame counter
c = 0;
time += timePerFrame;
c++;
// Start frame chronometer
time1 = SDL_GetTicks();Now let’s add the following lines to handle input events. This new while loop catches and manages SDL input events, along with keyboard and mouse events:
// If a key is released
if (events.type == SDL_KEYUP)
// If Q quit the application
end = true;
// If R reset the hit value
hit = 0.0f;
refresh = !refresh;
// If the mouse wheel is used
float s;
hit += 0.005f * s;
}Let’s add this following if condition.
// successful grab ZED image
}If this condition is true, we bind the frame buffer.
// Increment the CurrentIndex to point to the next texture within the output swap texture set. // CurrentIndex must be advanced round-robin fashion every time we draw a new frame ptextureSet->CurrentIndex = (ptextureSet->CurrentIndex + 1) % ptextureSet->TextureCount; // Get the current swap texture pointer auto tex = reinterpret_cast<ovrGLTexture*>(&ptextureSet->Textures[ptextureSet->CurrentIndex]); // Bind the frame buffer glBindFramebuffer(GL_FRAMEBUFFER, fboID); // Set its color layer 0 as the current swap texture glFramebufferTexture2D(GL_FRAMEBUFFER, GL_COLOR_ATTACHMENT0, GL_TEXTURE_2D, tex->OGL.TexId, 0); // Set its depth layer as our depth buffer glFramebufferTexture2D(GL_FRAMEBUFFER, GL_DEPTH_ATTACHMENT, GL_TEXTURE_2D, depthBuffID, 0); // Clear the frame buffer glClear(GL_COLOR_BUFFER_BIT | GL_DEPTH_BUFFER_BIT); glClearColor(0, 0, 0, 1);
for (int eye = 0; eye &amp;amp;amp;lt; 2; eye++)
// Bind the hit value
// Draw the ZED image
}Note: To keep this tutorial as simple as possible, the code provided here is not optimized for latency. To reduce latency, we recommend using CUDA-OpenGL interop which avoids unnecessary buffer transfers between CPU and GPU memory. A sample code “OpenGL GPU interop” is available in the ZED SDK.
} // if (refresh)
ovr_Destroy(hmd);
ovr_Shutdown();
SDL_Quit();
delete zed;
return -1;
}Now we’re able to display ZED images in the Rift DK2. But we would also like to see these images on our desktop SDL window. So we copy the frame to the mirror frame buffer.
// Copy the frame to the mirror buffer // which will be drawn in the SDL2 image glBindFramebuffer(GL_READ_FRAMEBUFFER, mirrorFBOID); glBindFramebuffer(GL_DRAW_FRAMEBUFFER, 0); GLint w = mirrorTexture->OGL.Header.TextureSize.w; GLint h = mirrorTexture->OGL.Header.TextureSize.h; glBlitFramebuffer(0, h, w, 0, 0, 0, w, h, GL_COLOR_BUFFER_BIT, GL_NEAREST); glBindFramebuffer(GL_READ_FRAMEBUFFER, 0); // Swap the SDL2 window SDL_GL_SwapWindow(window);
Note: This is for ZED SDK 1.0 only. Please see the latest SDK guides and documentation here.
Don’t forget to:
#include <iostream>
#include <Windows.h>
#include <GL/glew.h>
#include <stddef.h>
#include <SDL.h>
#include <SDL_syswm.h>
#include <OVR.h>
#include <OVR_CAPI.h>
#include <OVR_CAPI_GL.h>
#include <zed/Camera.hpp>
#include "Shader.hpp"
}Then we define a constant variable:
#define MAX_FPS 75
GLchar* OVR_ZED_VS =
"#version 330 core
uniform float hit;
out vec2 b_coordTexture;
void main()
b_coordTexture = in_texCoord;
GLchar* OVR_ZED_FS =
"#version 330 core
in vec2 b_coordTexture;
out vec4 out_color;
void main()
}";The shader above is a simple 2D texture shader. The only difference is the hit uniform variable. It is used to translate the texture on the X axis. We will explain how we use this variable later in this tutorial.
// Initialize SDL2 context
SDL_Init(SDL_INIT_VIDEO);
// Initialize Oculus context
if (OVR_FAILURE(result))
SDL_Quit();
return -1;
ovrSession hmd;
ovrGraphicsLuid luid;
ovr_Shutdown();
SDL_Quit();
return -1;
int winWidth = 1280;
int winHeight = 720;
// Create SDL2 Window
// Create OpenGL context
// Initialize GLEW
glewInit();
SDL_GL_SetSwapInterval(0);We create and initialize the ZED camera.
// Initialize the ZED Camera
sl::zed::Camera* zed = 0;
ovr_Destroy(hmd);
ovr_Shutdown();
SDL_Quit();
delete zed;
return -1;
}We initialize two OpenGL textures for the left and right images of the ZED.
GLuint zedTextureID_L, zedTextureID_R; // Generate OpenGL texture for left images of the ZED camera glGenTextures(1, &zedTextureID_L); glBindTexture(GL_TEXTURE_2D, zedTextureID_L); glTexImage2D(GL_TEXTURE_2D, 0, GL_RGBA, zedWidth, zedHeight, 0, GL_BGRA, GL_UNSIGNED_BYTE, NULL); glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_MAG_FILTER, GL_LINEAR); glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_MIN_FILTER, GL_NEAREST); glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_WRAP_S, GL_REPEAT); glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_WRAP_T, GL_REPEAT); // Generate OpenGL texture for right images of the ZED camera glGenTextures(1, &zedTextureID_R); glBindTexture(GL_TEXTURE_2D, zedTextureID_R); glTexImage2D(GL_TEXTURE_2D, 0, GL_RGBA, zedWidth, zedHeight, 0, GL_BGRA, GL_UNSIGNED_BYTE, NULL); glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_MAG_FILTER, GL_LINEAR); glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_MIN_FILTER, GL_NEAREST); glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_WRAP_S, GL_REPEAT); glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_WRAP_T, GL_REPEAT); glBindTexture(GL_TEXTURE_2D, 0);
ovrSizei bufferSize;
else
ovr_Destroy(hmd);
ovr_Shutdown();
SDL_Quit();
delete zed;
return -1;
GLuint fboID;
glGenFramebuffers(1, &fboID);
GLuint depthBuffID;
