Recording uncompressed stereo video at up to 60FPS in 2560Ă—720 resolution is a challenge for many platforms. To reduce the load on your hard drive, we provide two compression modes: Lossless and Lossy. These two modes now perform compression in parallel with I/O operations, improving throughput by 40-50%.
-The ZED Team
