      Tutorials
      Apr 22, 2019.
      How to Set Up a Multi-Depth Camera Network
      Lower TCO (total cost of ownership): Since ZED cameras don’t need their images processed locally, they can run on low-cost intermediary devices such as the NVIDIA Jetson Nano, cutting down on hardware setup requirements.
      General Workflow
      Software Setup
      • ZED SDK 2.8 or greater installed on all Senders and Receivers
      • Local network connecting all Senders and Receivers
      Sender
      1. Open the ZED camera with open()
      2. Set the streaming parameters
      3. Call enableStreaming() with the streaming parameters
      4. Grab the camera frames with grab()
      5. Disable the streaming before exiting with disableStreaming()
      // Open the camera
      zed.open();
      stream_params.bitrate = 8000;
      while (!exit_app) {
           zed.grab();
      // Disable streaming
      zed.disableStreaming();
      Refer to the following table to choose the ideal bitrate for your situation:
      Encoder
      Resolution
      FPS
      bitrate (kbps)
      AVCHD (H.264)
      HD2K
      HD1080
      HD720
      15
      30
      60
      8500
      12500
      7000
      HEVC (H.265)
      HD2K
      HD1080
      HD720
      15
      30
      60
      7000
      11000
      6000
      Receiver
      1. Set the input from the desired IP address and port by using setFromStream()
      2. Open the camera with open()
      3. Grab images directly from the stream with grab()
      // Set the input from stream
      // Open the camera
      while (!exit_app) {
         if (zed.grab() == SUCCESS) {
            // Any processing
      // Close the camera
      zed.close();
      Use getStreamingDeviceList() to list the available streaming devices. This function returns the IP address and port of all valid Senders present on the local network.
