      NewsTutorials
      Jul 3, 2015.
      Using the ZED Stereo Camera with MATLAB
      Note: This is for ZED SDK 1.2 only. Please see the latest MATLAB guide here.
      Introduction
      This tutorial will explain how to use the ZED 3D camera with MATLAB. You will learn how to capture images from the ZED and adjust camera parameters in MATLAB. Note that viewing and manipulating depth map data is not covered in this tutorial.
      You must have a MathWorks account (free) and MATLAB installed on your system. Of course, the ZED SDK has to be installed as well. Even if you’re new to MATLAB, this tutorial should be easy to follow.
      Getting Started
      >> webcamlist
      Then, read and accept the MathWorks auxiliary software license agreement. Click Next > and Install. This might take a while (around 10-15 seconds).
      When the setup process is finished, uncheck the “Show support package examples” check box and click on Finish.
      >> webcamlist
      and that should give you:
      ans ='ZED'
      Now grab an instance of the ZED camera with the following command line:
      >> cam = webcam
      cam =
      webcam with properties:
      Resolution: '2560x720'
      WhiteBalanceMode: 'auto'
      Sharpness: 4
      Saturation: 5
      Hue: 0
      Gain: 4
      WhiteBalance: 4600
      Contrast: 4
      Brightness: 4
      Exposure: 2
      ExposureMode: 'auto'
      Note that you can check whether the ZED camera works properly by using this command:
      >> preview(cam)
      You can now grab ZED frames with:
      >> img = snapshot(cam);
      You’ve just grabbed your first ZED frame in MATLAB. If you need real-time video capture, set up a loop. Fairly straightforward, isn’t it ? 😛
      The ZED Camera will stay active as long as you keep the cam variable in MATLAB’s environment. To turn off the ZED camera, use this command:
      >> clear cam
      clear all;close all;clc;
      zed = webcam('ZED')
      % set the desired resolution
      % get the image size
      ok = 1;
      % loop over frames
      while ok
          %capture the current image
          img = snapshot(zed);
          subplot(1,2,1);
          imshow(im_Left);
          title('Image Left');
          subplot(1,2,2);
          imshow(im_Right);
          title('Image Right');
      end
      % close the camera instance
      clear cam
