  • Tutorials
    Mar 12, 2019.
    Getting Started with ROS on Jetson Nano
    Installation
    Open a new terminal by pressing Ctrl + Alt + t or executing the “Terminal” application using the Ubuntu 18 launch system.
    Add a new apt key:
    [Note: the ROS GPG key has changed due to a security issue on the ROS build farm server. If you configured your Jetson Nano for ROS following this guide before the 24th June 2019, please follow this guide to replace the old key in the correct way]
    $ sudo apt update
    Install and initialize rosdep. rosdep enables you to easily install system dependencies for source code you want to compile and is required to run some core components in ROS:
    $ sudo rosdep init
    $ rosdep update
    Configure a catkin workspace
    $ catkin_make
    Getting Started with ZED stereo camera on Jetson Nano
    $ cd ~/catkin_ws/src
    Check the dependencies:
    Compile the ZED ROS wrapper:
    For ZED Mini:
