NewsTutorials
Jul 1, 2016.
How to Add Position and Head Tracking in Unity for VR
Note: This is for ZED SDK 1.2 only. Please see the latest Unity guide here.
In this tutorial you will learn how to track the movement of the ZED in Unity so that an identical virtual camera move can be reproduced in the game engine.
ZED Package for Unity
The ZED package for Unity includes assets, scripts, and a sample scene to assist with development. The ZED package contains the following subdirectories:
Prefab
Contains the main Unity prefab that is used to replace the regular Unity Camera within a scene: ZEDCamera.
Scenes
Contains a sample scene illustrating the use of ZED motion tracking in Unity: ZEDTrackingScene.
Scripts
Contains C# files that are used to interface the ZED and Unity components. The scripts are used by the Prefab.
Plugins
Contains sl_unitywrapper.dll, which enables C# scripts to communicate with the ZED SDK.
Download ZED Package for Unity
The package to use the ZED with Unity is available for download here.
To get started with virtual reality development in Unity, see Unity VR and Oculus documentation.
Create a new Project
  • Run Unity.
  • Select File > New.
  • Choose a Project name and a path.
  • Make sure 3D is selected and then click Create project.
Import the package
To import the ZED package in Unity, you have to go in AssetsImport packageCustom package.
You can now launch the ZEDTrackingScene sample. Make sure your ZED is connected, and that its line of sight is not obstructed. Run the demo scene, move your ZED around and watch the virtual camera reproduce the same movement in Unity.
Using ZED Prefab to move the virtual camera
The ZEDCamera prefab is the easiest way to add positional tracking in a virtual environment. To use, simply drag and drop the prefab into your scene.
By adding the ZEDCamera as a father of Unity main camera, you will have direct control of the virtual camera pose by head tracking. The starting position will be located at (0,0,0) in World space.
To change the starting position of the virtual camera, you need to add the ZEDCamera as a child of a parent GameObject. Camera movement will be relative to the reference GameObject absolute coordinates system.
Let’s add a few cubes to our scene. The virtual camera in Unity will now reproduce the same movement as the ZED.
Using ZED Prefab to move any GameObject
You can also move any object in the scene using ZEDCamera. Fix the position of the virtual camera, and drag a cube object as a child of ZEDCamera. Begin moving around the ZED, and see how the cube reproduces your hand or head movements.
Adding positional tracking with ZEDTracker class
For advanced Unity users, this section explains how to interface Unity with the ZED tracker in C#. Example code is included in ZEDCamera.cs.
Initialize the ZED
  // To get an instance of the camera
  ZED = ZEDTracker.GetInstance();
  // Create the camera
  ZED.CreateCamera();
Setup the tracker
To use the tracker you need to initialize it with a matrix. By default a 4×4 identity matrix is used.
  path = IdentityMatrix();
  if (!tracking) throw new ZEDException("Error, tracking not available");
  // Fill the Rt array
  for (int i = 0; i < 4; ++i) {
      for (int j = 0; j < 4; ++j) {
          Rt[i, j] = path[i * 4 + j];
The Rt transformation matrix represents both the rotation and translation of the ZED.
  // Get the translation
  Vector4 t_ = Rt.GetColumn(3);
  Vector3 translation = new Vector3(t_.x, t_.y, t_.z);
  // Get the rotation as a Unity compatible quaternion
  Quaternion rotation = ZEDTracker.QuaternionFromMatrix(Rt);
