  • News
    Dec 13, 2021.
    ZED Box: The Latest Embedded Mini-PC for Edge Computing
    Multiple power supply options
    • In development environments, using the external power supply makes more sense and is more convenient.
    • In deployment phases, powering the ZED Box over Ethernet makes more sense as a single Ethernet cable can stream the data and power the ZED Box. It is a powerful advantage and sometimes a requirement when deploying fleets of gateways as it enables faster and more efficient set-ups. Users can deploy ZED cameras anywhere reachable by Ethernet cabling, enabling long-range and outdoor coverage.
    Host on 256GB or 1TB SSD
    Dual USB 3.0 / 2.0
    Ready-to-use straight out of the box!
    Unique Hostname
    An Edge Computing system easy to install
    Experience the future of Computer Vision with Stereolabs
    Want to know more? Email us at: support@stereolabs.com
