Tutorials
Apr 22, 2019.
How to Set Up a Multi-Depth Camera Network
Lower TCO (total cost of ownership): Since ZED cameras don’t need their images processed locally, they can run on low-cost intermediary devices such as the NVIDIA Jetson Nano, cutting down on hardware setup requirements.
General Workflow
Software Setup
  • ZED SDK 2.8 or greater installed on all Senders and Receivers
  • Local network connecting all Senders and Receivers
Sender
  1. Open the ZED camera with open()
  2. Set the streaming parameters
  3. Call enableStreaming() with the streaming parameters
  4. Grab the camera frames with grab()
  5. Disable the streaming before exiting with disableStreaming()
// Open the camera
zed.open();
stream_params.bitrate = 8000;
while (!exit_app) {
     zed.grab();
// Disable streaming
zed.disableStreaming();
Refer to the following table to choose the ideal bitrate for your situation:
Encoder
Resolution
FPS
bitrate (kbps)
AVCHD (H.264)
HD2K
HD1080
HD720
15
30
60
8500
12500
7000
HEVC (H.265)
HD2K
HD1080
HD720
15
30
60
7000
11000
6000
Receiver
  1. Set the input from the desired IP address and port by using setFromStream()
  2. Open the camera with open()
  3. Grab images directly from the stream with grab()
// Set the input from stream
// Open the camera
while (!exit_app) {
   if (zed.grab() == SUCCESS) {
      // Any processing
// Close the camera
zed.close();
Use getStreamingDeviceList() to list the available streaming devices. This function returns the IP address and port of all valid Senders present on the local network.
