ROS is the natural choice when building a multi-sensory autonomous robot.After setting up the Jetson Nano with its JetPack image using our guide, we are going to install the latest version of ROS that runs on Ubuntu 18 Bionic Beaver: .
Open a new terminal by pressing Ctrl + Alt + t or executing the “Terminal” application using the Ubuntu 18 launch system.
Add a new apt key:
[Note: the ROS GPG key has changed due to a security issue on the ROS build farm server. If you configured your Jetson Nano for ROS following this guide before the 24th June 2019, please follow this guide to replace the old key in the correct way]
$ sudo apt update
Install and initialize rosdep. rosdep enables you to easily install system dependencies for source code you want to compile and is required to run some core components in ROS:
$ sudo apt install python-rosdep python-rosinstall python-rosinstall-generator python-wstool build-essential $ sudo rosdep init $ rosdep update
$ catkin_make
$ cd ~/catkin_ws/src
Check the dependencies:
Compile the ZED ROS wrapper:
For ZED Mini:
