Open a new terminal by pressing Ctrl + Alt + t or executing the “Terminal” application using the Ubuntu 18 launch system.
Add a new apt key:
[: the ROS GPG key has changed due to a ]
$ sudo apt update
Install and initialize rosdep. rosdep enables you to easily install system dependencies for source code you want to compile and is required to run some core components in ROS:
$ sudo apt install python-rosdep python-rosinstall python-rosinstall-generator python-wstool build-essential $ sudo rosdep init $ rosdep update
$ catkin_make
$ cd ~/catkin_ws/src
Check the dependencies:
Compile the ZED ROS wrapper:
For ZED Mini:
