Class containing GNSS data to be used for positional tracking as prior. More...
Functions | |
| void | setCoordinates (double latitude, double longitude, double altitude, bool is_radian=true) |
| Sets the sl::LatLng coordinates of sl::GNSSData. More... | |
| void | getCoordinates (double &latitude, double &longitude, double &altitude, bool in_radian=true) |
| Gets the sl::LatLng coordinates of the sl::GNSSData. More... | |
Attributes | |
| sl::Timestamp | ts |
| Timestamp of the GNSS position (must be aligned with the camera time reference). More... | |
| std::array< double, 9 > | position_covariance = {0.1 * 0.1, 0, 0, 0, 0.1 * 0.1, 0, 0, 0, 0.1 * 0.1} |
| Covariance of the position in meter (must be expressed in the ENU coordinate system). More... | |
| double | longitude_std |
| Longitude standard deviation. More... | |
| double | latitude_std |
| Latitude standard deviation. More... | |
| double | altitude_std |
| Altitude standard deviation. More... | |
| GNSS_STATUS | gnss_status = sl::GNSS_STATUS::UNKNOWN |
| Represents the current status of GNSS. More... | |
| GNSS_MODE | gnss_mode = sl::GNSS_MODE::UNKNOWN |
| Represents the current mode of GNSS. More... | |
Protected Attributes | |
| double | longitude |
| Longitude coordinate. More... | |
| double | latitude |
| Latitude coordinate. More... | |
| double | altitude |
| Altitude coordinate. More... | |
| void setCoordinates | ( | double | latitude, |
| double | longitude, | ||
| double | altitude, | ||
| bool | is_radian = true |
The sl::LatLng coordinates could be expressed in degrees or radians.
| latitude | Latitude coordinate. |
| longitude | Longitude coordinate. |
| altitude | Altitude coordinate. |
| is_radian | If the inputs are expressed in radians or in degrees. |
| void getCoordinates | ( | double & | latitude, |
| double & | longitude, | ||
| double & | altitude, | ||
| bool | in_radian = true |
| is_radian | Should the output be expressed in radians or degrees. |
| sl::Timestamp ts |
| std::array<double, 9> position_covariance = {0.1 * 0.1, 0, 0, 0, 0.1 * 0.1, 0, 0, 0, 0.1 * 0.1} |
For eph, epv GNSS sensors, set it as follow: {eph*eph, 0, 0, 0, eph*eph, 0, 0, 0, epv*epv}.
| double longitude_std |
| double latitude_std |
| double altitude_std |
| GNSS_STATUS gnss_status = sl::GNSS_STATUS::UNKNOWN |
| GNSS_MODE gnss_mode = sl::GNSS_MODE::UNKNOWN |
protected |
protected |
protected |
