Structure containing a set of runtime properties of a certain class ID for the object detection module using a custom model. More...
Data Fields | |
| int | class_id |
| Index of the class represented by this set of properties. | |
| bool | enabled |
| Whether the object object is kept or not. | |
| float | detection_confidence_threshold |
| Confidence threshold. More... | |
| bool | is_grounded |
| Provide hypothesis about the object movements (degrees of freedom or DoF) to improve the object tracking. More... | |
| bool | is_static |
| Provide hypothesis about the object staticity to improve the object tracking. More... | |
| float | tracking_timeout |
| Maximum tracking time threshold (in seconds) before dropping the tracked object when unseen for this amount of time. More... | |
| float | tracking_max_dist |
| Maximum tracking distance threshold (in meters) before dropping the tracked object when unseen for this amount of meters. More... | |
| float | max_box_width_normalized |
| Maximum allowed width normalized to the image size. More... | |
| float | min_box_width_normalized |
| Minimum allowed width normalized to the image size. More... | |
| float | max_box_height_normalized |
| Maximum allowed height normalized to the image size. More... | |
| float | min_box_height_normalized |
| Minimum allowed height normalized to the image size. More... | |
| float SL_CustomObjectDetectionProperties::detection_confidence_threshold |
From 1 to 100, with 1 meaning a low threshold, more uncertain objects and 99 very few but very precise objects.
Default: 20.f
| bool SL_CustomObjectDetectionProperties::is_grounded |
| bool SL_CustomObjectDetectionProperties::is_static |
| float SL_CustomObjectDetectionProperties::tracking_timeout |
By default, let the tracker decide internally based on the internal sub class of the tracked object. Only valid for static object.
| float SL_CustomObjectDetectionProperties::tracking_max_dist |
By default, do not discard tracked object based on distance. Only valid for static object.
| float SL_CustomObjectDetectionProperties::max_box_width_normalized |
Any prediction bigger than that will be filtered out. Default: -1 (no filtering)
| float SL_CustomObjectDetectionProperties::min_box_width_normalized |
Any prediction smaller than that will be filtered out. Default: -1 (no filtering)
| float SL_CustomObjectDetectionProperties::max_box_height_normalized |
| float SL_CustomObjectDetectionProperties::min_box_height_normalized |
