      News
      Dec 13, 2021.
      ZED Box: The Latest Embedded Mini-PC for Edge Computing
      Multiple power supply options
      • In development environments, using the external power supply makes more sense and is more convenient.
      • In deployment phases, powering the ZED Box over Ethernet makes more sense as a single Ethernet cable can stream the data and power the ZED Box. It is a powerful advantage and sometimes a requirement when deploying fleets of gateways as it enables faster and more efficient set-ups. Users can deploy ZED cameras anywhere reachable by Ethernet cabling, enabling long-range and outdoor coverage.
      Host on 256GB or 1TB SSD
      Dual USB 3.0 / 2.0
      Ready-to-use straight out of the box!
      Unique Hostname
      An Edge Computing system easy to install
      Experience the future of Computer Vision with Stereolabs
      Getting Started NowBuy Now
      Want to know more? Email us at: support@stereolabs.com
