UpdatesNews
Dec 9, 2025.
Introducing the new ZED X One camera series for Physical AI
Compact. Rugged. Surround. Physical AI and robot perception just got a major upgrade.
The new eyes of Physical AI
The era of Physical AI has arrived. Machines can now be automated and trained to perceive the world with human-like precision. But as engineers push the boundaries of what these robots can do, they keep running into the same wall: physics.
As robots become more complex, every millimeter of space matters. Engineers face the constant challenge of fitting industrial-grade perception into ever-tighter spaces, without compromising performance.
Today, we are answering that challenge. We are proud to announce the launch of two new cameras designed specifically for the tight constraints and harsh environments of physical AI and data collection: the ZED X One S and the ZED X One Core.
Tailored for the future of automation
Our new cameras are specifically tailored for the next generation of physical AI. They can be seamlessly integrated onto:
  • Humanoids: Ultra-compact, vibration-resistant, and wide-angle for full surround vision and SLAM.
  • Robotic Arms: Small enough to mount directly on the wrist for precise manipulation tasks, along with a fisheye lens for ultra-close-range vision.
  • Factory Automation: Exceptional image quality and rugged design to withstand harsh factory and warehouse environments, enabling AI-driven automation at scale.
Reference design for a humanoid robot
ZED X One S: Smaller. Tougher. Wider.
When we launched the ZED X One, we set a new standard for high-fidelity data collection and machine perception. But as robots become more agile, more integrated, and operating in harsher environments, their sensors must evolve with them.
We took the industry-leading performance of the ZED X One and condensed it. It’s now 35% smaller, IP69K water-resistant, and available with a new fisheye option. Meet the ZED X One S.
S for Slim
Space is a luxury in modern robotics. The ZED X One S features a 35% smaller volume than the standard ZED X One. This compact form factor combined with low-latency GMSL connectivity allows it to fit flush inside AMRs, forklift forks, integrate seamlessly into robotic arms, and serve as a low-profile wrist cam on humanoids without compromising mobility.
S for Sealed
Factory floors and outdoor environments are unforgiving. We engineered the ZED X One S to be rated IP69K. It is impervious to shock, heavy vibrations, dust, and high-temperature environments. Whether it's on a humanoid in a dusty warehouse or an agricultural bot in the rain, the S is built to survive.
S for Surround
Perception isn't just about looking forward; it's about awareness. Built on the same proven sensor that made ZED X One a standard for high-performance vision, our new Fisheye optics option enables surround perception. With an ultra-wide 190° field of view, you can achieve complete environmental awareness, SLAM and object detection combining ZED X and ZED X One S, simplifying your robot architecture.
ZED X One Core: For deep OEM integration
The ZED X One Core is our first MIPI camera designed for barebone integration. Created for robotics OEMs and system integrators who need a fully embedded, low-latency, low-power image sensor module, the Core allows you to embed industrial-grade vision directly into the chassis of your robot or system. It provides:
  • Direct MIPI CSI-2 connectivity
  • Ultra-compact design for seamless integration inside robots
  • The same high-quality sensor and imaging performance as ZED X One
  • Full ZED SDK compatibility
  • NVIDIA Thor-ready with Lattice Sensor Bridge
It’s the perfect choice for manufacturers designing custom sensing modules, high volume or compact robots, where every millimeter counts.
Technical specifications at a glance
Feature
ZED X One S
ZED X One Core
ZED X One
ZED X One 4K
Sensor type
2MP Global Shutter
2MP Global Shutter
2MP Global Shutter
8MP Rolling Shutter
Interface
GMSL2
MIPI
GMSL2
GMSL2
Lens option (DxHxV)
91°x 80° x 52° (Narrow)
120°x 110°x 80°(Wide)
218° x 204°x 137°(Fisheye)
118.8°x109.9°x71.8°(Wide)
Resolution and framerate
1920x1200 @60fps, 1920x1080 @60fps, 960x600 @120fps
3840x2160 @15fps, 1920x1080 @60fps, 960x600 @120fps
IP-Rating
IP69K (Wide)
Dimensions
25 x 25 x 38.7cm
(0.98 x 0.98 x 1.52'')
27 x 27 x 34.52 mm
(1.06 x 1.06 x 1.34'')
31 x 31 x 52.7mm
(1.22 x 1.22 x 2.07'')
31 x 31 x 57.8mm
(1.22 x 1.22 x 2.28'')
Optimized for multi-camera capture and 24/7 data collection
The ZED X One architecture is built to scale AI automation from day one. It supports hardware synchronization of up to 16 cameras on a single gateway, with a capture and ISP pipeline engineered to manage simultaneous streams with microsecond-level precision. Developers can build cohesive 360° surround-view systems that enable safe AI navigation, manipulation, and interaction.
For 24/7 continuous operation in warehouses, logistics hubs, and data factories, the ZED X One series also delivers the reliability required for nonstop perception:
  • Industrial-grade GMSL2 serializers: High-bandwidth NV12 raw streaming with ultra-low latency for real-time AI processing.
  • Health-monitoring APIs: Real-time insights into thermal performance and link integrity, keeping mission-critical perception stacks stable around the clock.
A complete industrial ecosystem
Deploying Physical AI at scale requires more than sensors, it requires an ecosystem. The ZED X One series is supported by a full suite of hardware, compute, and software tools to streamline integration and accelerate production-grade deployments.
  • Multiple Mounting Options: Industrial-ready flat, angled, and compact mounts remove the need for custom mechanical design and simplify installation on robots, arms, and factory equipment.
  • Compute Ecosystem: Fully optimized for the NVIDIA Jetson Orin lineup available from leading compute partners, and forward-compatible with NVIDIA Jetson Thor, ensuring your hardware investment is ready for the next leap in edge AI performance.
  • Software Integrations: Native support for ROS 2, Isaac ROS, Python, GStreamer, and PyTorch. Using NITROS (NVIDIA Isaac Transport for ROS), the ZED ROS 2 Wrapper delivers up to 10× lower latency through direct GPU memory sharing, eliminating costly CPU–GPU copies and enabling real-time performance at scale.
Get your ZED X One now
Get your ZED X One S and ZED X One Core now from our online shop.
