      Tutorials
      Jan 14, 2019.
      Getting Started
      Requirements
      • Oculus Rift or HTC Vive VR headset
      • ZED Mini
      • Leap Motion with VR kit
      • Unity 2017.1 or greater
      Hardware Setup
      If you haven’t already, make sure you’ve installed the ZED SDK and Leap Motion Orion.
      Setting Up Unity
      • Download the ZED Unity plugin and import it into Unity using Assets -> Import Package -> Custom Package
      • Do the same with the Leap Motion Unity Core Assets
      • Enable VR by going to Edit -> Project Settings -> Player, then in the Player menu, opening XR Settings and checking Enable XR
      • Open the ZED Planetarium example scene via the Project window via ZED -> Examples -> Planetarium -> Scene
      • In the Project window, navigate to LeapMotion -> Core -> Prefabs and drag the Leap Rig prefab into the scene.
      Combining the Rigs
      • Expand ZED_Rig_Stereo, right click on the Camera_eyes object and click Create Empty. Name it “Leap Offset”
      • Expand Leap Rig and click on Main Camera
      • In the Inspector, disable the Camera component – we’ll be using the ZED’s camera for the final image instead.
      • In the Leap XR Service Provider component, set Device Offset Mode to “Transform”. This causes the rig to follow a particular object instead of the VR camera.
      • Drag and drop the new Leap Offset object from the Hierarchy into the Device Origin field
      • Without closing the scene, take off the headset, select Leap Offset and adjust its transforms to line it up properly. The Y position is most important, but make sure to move your hand around to make sure all axes are properly aligned. If using a Vive, you may also need to adjust the X rotation slightly.
      • When you can see in the Game window that Leap Offset is in a good place, click the gear icon in the top right of Leap Offset‘s Transform component, and click Copy Component
      • Stop the scene
      • Click on that same gear, followed by Paste Component Values
      • Save the scene
      Adding Physics
      • In the Project window, navigate to LeapMotion -> Core -> Prefabs -> HandModelsPhysical
      • Drag and drop RigidRoundHand_L and RigidRoundHand_R to the Hand Models object in the Leap Rig to make them children of it
      • Select the Hand Models object.
      • In the Inspector under Hand Model Manager, expand Model Pool and Capsule Hands
      • In the Left/Right Model fields, replace the Capsule hands with the RigidRoundHands you just added.
      • Delete the Capsule Hands that are children of Hand Models
      • Expand the Planetarium object, and the Earth object below that
      • Select all the planets, the Sun, and the Moon (a child of Earth) at once. In the Inspector, add a Rigidbody component
      • Uncheck Use Gravity and check Is Kinematic on these new Rigidbody components
      • With the objects still selected, also add a Sphere Collider component
      • Select the objects individually and adjust the Radius value of the Sphere Collider until you see its bounds fit the planet in the Scene window
      Result
      Kadek
      Kadek
      @KadekASatriadi
      ·Follow
      Need more tea! #madewithunity @Stereolabs3D @LeapMotion
      Watch on Twitter
      24
      Reply
      Read more on Twitter
      Yujin Ariza
      Yujin Ariza
      @YujinAriza
      ·Follow
      building a food chain #mixedreality #vr #leapmotion #zedcamera #oculusrift
      Watch on Twitter
      237
      Reply
      Read 6 replies
      Yujin Ariza
      Yujin Ariza
      @YujinAriza
      ·Follow
      Watch on Twitter
      237
      Reply
      Read 6 replies
