  • NewsTutorials
    Jun 28, 2015.
    Using the ZED Camera With OpenCV
    Important: This article is outdated (ZED SDK 1.2). Please see the new OpenCV guide here.
    Redirect me to the updated tutorial
    Introduction
    depth grab
    Code
    Explanation
    ** Using ZED with OpenCV
    #include <iostream>
    // OpenCV
    // ZED
    #include <zed/Camera.hpp>
    // Input from keyboard
    char keyboard = ' ';
      // Quit if an error occurred
      if (err != sl::zed::SUCCESS)
        delete zed;
        return 1;
      // Create OpenCV windows
      // Settings for windows
      // Loop until 'q' is pressed
      while (keyboard != 'q')
          // Retrieve left color image
          // Retrieve depth map
        keyboard = cv::waitKey(30);
      delete zed;
    #include <iostream>
    // OpenCV
    // ZED
    Do not forget to add the links to OpenCV (headers and libs) and ZED SDK (headers and libs).
    1. Initialize the ZED camera
      delete zed;
      return 1;
    2. Create OpenCV windows
    Now, assuming the initialization was correct, we can create our OpenCV matrix and OpenCV windows with the correct resolutions and types.
    3. Capture and display color image and depth
    Let’s write our main loop. The simplest way is to create a ‘while’ loop and handle all the events with OpenCV.
    And that’s all we need! You can now build and run the application. You should see on your screen the two following windows: “Depth” and “Image”.
    depth grab
