Important: This article is outdated (ZED SDK 1.2). Please see the new OpenCV guide .
depth grab
** Using ZED with OpenCV
#include <iostream>
// OpenCV
// ZED
#include <zed/Camera.hpp>
// Input from keyboard
char keyboard = ' ';
// Quit if an error occurred
if (err != sl::zed::SUCCESS)
delete zed;
return 1;
// Create OpenCV windows
// Settings for windows
// Loop until 'q' is pressed
while (keyboard != 'q')
// Retrieve left color image
// Retrieve depth map
keyboard = cv::waitKey(30);
delete zed;
}Let’s break down the code piece by piece.
#include <iostream>
// OpenCV
// ZED
}Do not forget to add the links to OpenCV (headers and libs) and ZED SDK (headers and libs).
delete zed;
return 1;
}Now, assuming the initialization was correct, we can create our OpenCV matrix and OpenCV windows with the correct resolutions and types.
// Initialize color image and depth int width = zed->getImageSize().width; int height = zed->getImageSize().height; cv::Mat image(height, width, CV_8UC4,1); cv::Mat depth(height, width, CV_8UC4,1);
cv::Mat depthDisplay(displaySize, CV_8UC4);Let’s write our main loop. The simplest way is to create a ‘while’ loop and handle all the events with OpenCV.
// Grab frame and compute depth in FILL sensing mode grab(sl::zed::SENSING_MODE::FILL))
cv::imshow("Depth", depthDisplay);And that’s all we need! You can now build and run the application. You should see on your screen the two following windows: “Depth” and “Image”.
depth grab
