This is the complete list of members for InitParameters, including all inherited members.
| async_grab_camera_recovery | InitParameters | |
| async_image_retrieval | InitParameters | |
| camera_disable_self_calib | InitParameters | |
| camera_fps | InitParameters | |
| camera_image_flip | InitParameters | |
| camera_resolution | InitParameters | |
| coordinate_system | InitParameters | |
| coordinate_units | InitParameters | |
| decode(const String &serialized_content, SERIALIZATION_FORMAT format=SERIALIZATION_FORMAT::JSON) | InitParameters | |
| depth_maximum_distance | InitParameters | |
| depth_minimum_distance | InitParameters | |
| depth_mode | InitParameters | |
| depth_stabilization | InitParameters | |
| enable_image_enhancement | InitParameters | |
| enable_image_validity_check | InitParameters | |
| enable_right_side_measure | InitParameters | |
| encode(String &serialized_content, SERIALIZATION_FORMAT format=SERIALIZATION_FORMAT::JSON) const | InitParameters | |
| grab_compute_capping_fps | InitParameters | |
| InitParameters(RESOLUTION camera_resolution_=RESOLUTION::AUTO, int camera_fps_=0, bool svo_real_time_mode_=false, DEPTH_MODE depth_mode_=DEPTH_MODE::ULTRA, UNIT coordinate_units_=UNIT::MILLIMETER, COORDINATE_SYSTEM coordinate_system_=COORDINATE_SYSTEM::IMAGE, int sdk_verbose_=1, int sdk_gpu_id_=-1, float depth_minimum_distance_=-1., float depth_maximum_distance_=-1., bool camera_disable_self_calib_=false, int camera_image_flip_=FLIP_MODE::OFF, bool enable_right_side_measure_=false, String sdk_verbose_log_file_=String(), int depth_stabilization_=1, CUcontext sdk_cuda_ctx_=CUcontext(), InputType input_type=InputType(), String optional_settings_path_=String(), bool sensors_required_=false, bool enable_image_enhancement_=true, String optional_opencv_calibration_file_=String(), float open_timeout_sec_=5.0f, bool async_grab_camera_recovery=false, float grab_compute_capping_fps=0, int enable_image_validity_check=false, bool async_image_retrieval=false) | InitParameters | |
| input | InitParameters | |
| load(String filename, SERIALIZATION_FORMAT format=SERIALIZATION_FORMAT::AUTO) | InitParameters | |
| open_timeout_sec | InitParameters | |
| operator!=(const InitParameters ¶m1) const | InitParameters | |
| operator==(const InitParameters ¶m1) const | InitParameters | |
| optional_opencv_calibration_file | InitParameters | |
| optional_settings_path | InitParameters | |
| save(String filename, SERIALIZATION_FORMAT format=SERIALIZATION_FORMAT::LEGACY) const | InitParameters | |
| sdk_cuda_ctx | InitParameters | |
| sdk_gpu_id | InitParameters | |
| sdk_verbose | InitParameters | |
| sdk_verbose_log_file | InitParameters | |
| sensors_required | InitParameters | |
| svo_real_time_mode | InitParameters |
