Using Leap Motion and ZED Mini for AR Hand Tracking | Stereolabs
Enable VR by going to Edit -> Project Settings -> Player, then in the Player menu, opening XR Settings and checking Enable XR
Open the ZED Planetarium example scene via the Project window via ZED -> Examples -> Planetarium -> Scene
In the Project window, navigate to LeapMotion -> Core -> Prefabs and drag the Leap Rig prefab into the scene.
Combining the Rigs
Expand ZED_Rig_Stereo, right click on the Camera_eyes object and click Create Empty. Name it “Leap Offset”
Expand Leap Rig and click on Main Camera
In the Inspector, disable the Camera component – we’ll be using the ZED’s camera for the final image instead.
In the Leap XR Service Provider component, set Device Offset Mode to “Transform”. This causes the rig to follow a particular object instead of the VR camera.
Drag and drop the new Leap Offset object from the Hierarchy into the Device Origin field
Without closing the scene, take off the headset, select Leap Offset and adjust its transforms to line it up properly. The Y position is most important, but make sure to move your hand around to make sure all axes are properly aligned. If using a Vive, you may also need to adjust the X rotation slightly.
When you can see in the Game window that Leap Offset is in a good place, click the gear icon in the top right of Leap Offset‘s Transform component, and click Copy Component
Stop the scene
Click on that same gear, followed by Paste Component Values
Save the scene
Adding Physics
In the Project window, navigate to LeapMotion -> Core -> Prefabs -> HandModelsPhysical
Drag and drop RigidRoundHand_L and RigidRoundHand_R to the Hand Models object in the Leap Rig to make them children of it
Select the Hand Models object.
In the Inspector under Hand Model Manager, expand Model Pool and Capsule Hands
In the Left/Right Model fields, replace the Capsule hands with the RigidRoundHands you just added.
Delete the Capsule Hands that are children of Hand Models
Expand the Planetarium object, and the Earth object below that
Select all the planets, the Sun, and the Moon (a child of Earth) at once. In the Inspector, add a Rigidbody component
Uncheck Use Gravity and check Is Kinematic on these new Rigidbody components
With the objects still selected, also add a Sphere Collider component
Select the objects individually and adjust the Radius value of the Sphere Collider until you see its bounds fit the planet in the Scene window
