ZED ROS 2 Wrapper Custom Messages
All the custom messages used by the ZED ROS 2 Wrapper are defined in the zed-ros2-interfaces repository and are installed along with the zed-msgs package:
sudo apt install ros-<ros2-distro>-zed-msgs
Node Heartbeat #
The zed_interfaces/Heartbeat message, published on the ~/status/heartbeat topic, is defined as:
# Message to notify that the node is alive to other nodes
# idx of the message
uint64 beat_count
# namespace of the node
string node_ns
# name of the node
string node_name
# full node name
string full_name
# serial number of the input camera
uint32 camera_sn
# data from an svo?
bool svo_mode
# data from simulation?
bool simul_mode
Node Health Status #
The zed_interfaces/HealthStatusStamped message, published on the ~/status/health topic, is defined as:
# Message to provide information concerning the status of health of the ZED Camera
# Standard Header
std_msgs/Header header
# ZED Camera serial number
uint32 serial_number
# ZED Camera name
string camera_name
# Image quality is degraded
bool low_image_quality
# Environmental light conditions are not optimal
bool low_lighting
# Depth reliability is low
bool low_depth_reliability
# Motion sensors reliability is low
bool low_motion_sensors_reliability
SVO Status #
The zed_interfaces/SVOStatus message, published on the ~/status/svo topic, is defined as:
# Message to provide information concerning the status of the SVO playback
# SVO File name
string file_name
# SVO playback status
uint8 status
# SVO playback status constants
uint8 STATUS_PLAYING=0
uint8 STATUS_PAUSED=1
uint8 STATUS_END=2
# SVO frame timestamp
uint64 frame_ts
# SVO playback position
uint32 frame_id
# SVO total number of frames
uint32 total_frames
# SVO loop status
bool loop_active
# SVO loop count
uint32 loop_count
# SVO real-time mode status
bool real_time_mode
Plane Detection result #
The zed_interfaces/PlaneStamped message, published by the Plane Detection module, is defined as:
# Standard Header
# Mesh of the place
shape_msgs/Mesh mesh
# Representation of a plane, using the plane equation ax + by + cz + d = 0
shape_msgs/Plane coefficients
# Normal vector
geometry_msgs/Point32 normal
# Center point
geometry_msgs/Point32 center
# Plane pose relative to the global reference frame
geometry_msgs/Transform pose
# Width and height of the bounding rectangle around the plane contours
float32[2] extents
# The polygon bounds of the plane
geometry_msgs/Polygon bounds
Depth information #
The zed_interfaces/DepthInfoStamped message is defined as:
# Standard Header
# Miminum measured depth
float32 min_depth
# Maximum measured depth
float32 max_depth
Positional Tracking status #
The zed_interfaces/PosTrackStatus message is defined as:
# Status constants
# SEARCHING - The camera is searching for a previously known position to locate itself
# OK - Positional tracking is working normally
# OFF - Positional tracking is not enabled.
# FPS_TOO_LOW - Effective FPS is too low to give proper results for motion tracking. Consider using PERFORMANCES parameters (DEPTH_MODE_PERFORMANCE, low camera resolution (VGA,HD720))
# SEARCHING_FLOOR_PLANE - The camera is searching for the floor plane to locate itself related to it, the REFERENCE_FRAME::WORLD will be set afterward.
uint8 SEARCHING=0
uint8 OK = 1
uint8 OFF = 2
uint8 FPS_TOO_LOW = 3
uint8 SEARCHING_FLOOR_PLANE = 3
# Status
uint8 status
GNSS Fusion status #
The zed_interfaces/GNSSFusionStatus message, published on the ~/pose/filtered/status topic, is defined as:
# GNSS_FUSION_STATUS
# Represents the current state of GNSS fusion for global localization.
# OK - The GNSS fusion module is calibrated and working successfully.
# OFF - The GNSS fusion module is not enabled.
# CALIBRATION_IN_PROGRESS - Calibration of the GNSS/VIO fusion module is in progress.
# RECALIBRATION_IN_PROGRESS- Re-alignment of GNSS/VIO data is in progress, leading to potentially inaccurate global position.
uint8 OK = 0
uint8 OFF = 1
uint8 CALIBRATION_IN_PROGRESS = 2
uint8 RECALIBRATION_IN_PROGRESS = 3
uint8 gnss_fusion_status
Object Detection and Body Tracking results #
The Object Detection and the Body Tracking modules publish data on the detected objects and body topics by using the same custom message.
The zed_interfaces/ObjectsStamped message is defined as:
# Standard Header
# Array of `object_stamped` topics
zed_interfaces/Object[] objects
where zed_interfaces/Object is defined as:
# Object label
string label
# Object label ID
int16 label_id
# Object sub-class label (Only for the `MULTI_CLASS_BOX` model)
string sublabel
# Object confidence level (1-99)
float32 confidence
# Object 3D centroid position
float32[3] position
# Position covariance
float32[6] position_covariance
# Object 3D velocity
float32[3] velocity
# Is Object tracking available?
bool tracking_available
# Tracking available
# Tracking state
# 0 -> OFF (object not valid)
# 1 -> OK
# 2 -> SEARCHING (occlusion occurred, trajectory is estimated)
# 3 -> TERMINATE (This is the last searching state of the track. The track will be deleted in the next frame).
int8 tracking_state
# Action state
# 0 -> IDLE
# 2 -> MOVING
int8 action_state
# 2D Bounding box projected to the Camera image
zed_msgs/BoundingBox2Di bounding_box_2d
# 3D Bounding box in world frame
zed_msgs/BoundingBox3D bounding_box_3d
# 3D dimensions (width, height, lenght)
float32[3] dimensions_3d
# Person Head Detection specific fields
# 2D Bounding box projected to Camera image of the person head
zed_msgs/BoundingBox2Df head_bounding_box_2d
# 3D Bounding box in world frame of the person head
zed_msgs/BoundingBox3D head_bounding_box_3d
# 3D position of the centroid of the person head
float32[3] head_position
# Body Tracking specific fields
# Is skeleton available?
bool skeleton_available
# Skeleton format
# 0 -> POSE_18
# 1 -> POSE_34
# 2 -> POSE_38
# 3 -> POSE_70
int8 body_format
# 2D Person skeleton projected to Camera image
zed_msgs/Skeleton2D skeleton_2d
# 3D Person skeleton in world frame
zed_msgs/Skeleton3D skeleton_3d
And all the submessages are defined as following:
zed_interfaces/BoundingBox2Df:
# 0 ------- 1
# 3 ------- 2
zed_interfaces/Keypoint2Df[4] corners
zed_interfaces/BoundingBox2Di:
# 0 ------- 1
# 3 ------- 2
zed_interfaces/Keypoint2Di[4] corners
zed_interfaces/BoundingBox3D:
# 1 ------- 2
# 0 ------- 3 |
# | 5.......| 6
# 4 ------- 7
zed_interfaces/Keypoint3D[8] corners
zed_interfaces/Keypoint2Df:
float32[2] kp
zed_interfaces/Keypoint2Di:
uint32[2] kp
zed_interfaces/Keypoint3D:
float32[3] kp
zed_interfaces/Skeleton2D:
# Skeleton joints
zed_interfaces/Keypoint2Df[70] keypoints
zed_interfaces/Skeleton3D:
# Skeleton joints
zed_interfaces/Keypoint3D[70] keypoints
